If I were developing a light and happened to be ready to announce it and someone else brought it out, my own development would be scrapped. Done already. If Simon is the enthusiast I think he is he won’t be making a reflectored C8 simply because someone else already has it.
So, at the end of the day, if you want a reflectored triple C8, buy a Sofirn.
If only Simon would make a 18650 extension tube for this new C8… It would open up the possibilities for more ways to mod it, using 6v or 12v leds/drivers combos. That way the “finnish” on this light can be put to good use.
The C8 concept has been around for a while, I didn’t like the 3 legged style of em for a long time but of course I eventually wound up with several. I reviewed the first Sofirn triple and made some suggestions on how to improve it, as did several others, then they came out with the side switch version and they had a hit!
I have always wished this size light were done something like this new C8+, much more to my liking with the fins and heavy knurling. Can’t wait to see one!
Cant they bump up the lumens atleast? like the astrolux version that does 1300 or so… since it has more cooling fins it shouldnt be an issue? I mean since the name is c8+ the + to me should be an increase in lumens and throw also no ?
That would require Convoy to adapt a new type of driver (FET or FET+7135) and Simon has been very conservative in the past with drivers, he goes for simple and limited power, probably because his market is partly outside the flashoholics community. That said, this new C8 would have no problems at all handling a direct driver like the BLF-A6.
I’ve been discussing this with Simon. Yes, he has been fairly conservative with his driver choices in the past. We have to keep in mind that not all of his market is a bunch of power-hungry freaks like us. :zipper_mouth_face:
He very much appreciates the BLF community though and I see more power in our future. Something along the lines of an A6 type driver is exactly what I’ve been leaning towards. No decisions have been made yet but there is certainly much more goodness coming from Convoy in the future. :sunglasses:
I think the tint choice of the Convoy C8, but with the Astrolux C8 high-output driver, would be a real winner. I wouldn’t want the exact same firmware as the Astrolux (which is the BLF A6 firmware), but something along the lines of the biscotti firmware would be good.
Or, for a few more bucks, an XHP35 HI emitter, along with a decent boost-driver, would give both high-output and good efficiency. IMO, that should be the next evolution of the Convoy C8. May as well leap-frog the budget competition.
Not a lot of point in trying to use a Boost driver with the XHP-35 in a single 18650 light as the same lumens and essentially the same beam can be had with a well driven XP-L HI. Similar amperage will be drawn from the cell in both cases, so there’s no real gain to go with a boosted 12V emitter. Just a more complicated driver that costs more.
That’s a fair point if you use the light only in maximum, which is probably what most people do with a C8. I was thinking of more efficient modes other than max, but I suppose that’s something more applicable to a light like the BLF A6. I think the XHP35 is supposed to be brighter and more efficient than the XP-L, but perhaps not worth the extra expense of a boost driver in a budget light.
Still, it would be nice to know what a C8 with an XHP35 HI would cost, before giving up on it.
