Closed NEW Soraa 95CRI 3000k PAR38 GU24 Recessed/Kitchen/indoor/outdoor lights (I just want them gone)
Closed
OK here is the deal
This is meant for folks who can use them.
FYI these are NOT MR16 bulbs these are big long bulbs. Great for use in kitchens (but you need to plan or confirm they will fit) could certainly work in Baths also (same caveat), lets make sure what I am sending is what your expecting (remember the #2 goal here is to get them used, not just to sit at a new address) thank you again
Sending them to folks who “plan” on flipping them (because these are very expensive lights) is NOT the reason I am making the offer.
I wanted to give something back to BLF at large. I have been trying to sell them and I can tell you that the world does not get “PAR 38” bulbs especially ones with messy water damaged boxes. So if you don’t know what these are, but figure you can always throw them out (your missing the point) and you may want to save your money (and my time) shipping to just throw them out later. (not trying to sound harsh, but seeking to be clear)
Brand new
SP38G-18-36D-930-03
AND/OR
SP38G-18-25D-930-03
aka 3000k 95CRI lights
Expect factory box to be water damaged/(will remove from box and pack loose with padding and lid from box) each But has good intact labels so don’t worry about confusion. They have been 100% tested and are fine (as the bulbs are water proof) but no good for retail sale
Trying to juggle to fill every ones order. It looks like shipping is $20 per LG Flat rate USPS box (I just want them gone)
(open to shipping any odd quantities) The master shipping cases dissolved first, so I’m planning on shipping “smaller amounts” USPS medium or large flat rate boxes, still working out qty per. And/or UPS for larger qty (would like to serve as many folks as possible but #1 objective is to just make them disappear.
Just so you know they way I tested them is I bought Cheap GU24 to E26/7 adapters for a $1-$2 each so (adapters not included) then these can be used in “normal bulb sockets” That is how I tested them. But allow for a 5 inch long bulbs plus adapter if used and a 5 inch wide bulb so some fixtures will be too small. For example not good with lamps with shades (true, but LOL).
Bulbs will be weighted and prioritized in order of posted responses (below)/finalized count, acceptable degree spec, address and payment also matter. Will try to stay with first complete order first served. (“cases” no longer available, all orders on an individual basis. actual project size matters).
Please include quantity desired (meaning count your fixtures or project plan for total used) and preferred beam width (and also if beam width is a deal breaker) in PM, will respond to each member separately.
Will close or remove posting when out of stock. So as long as you see the ad I am still making orders.
If you haven’t/cant wire your project for GU24 you can still use these but they need an adapter to fit in normal sockets (adapter shown below)
I'll take a case. PM incoming. Thank you.
EDIT: Given the update to the OP, I have reduced the quantity requested.
I’ll take a case too! Thank you!!
I’ll take a case if ya still got, tnx!
Wide/flood preferred, but either is fine. Track lighting, over a dozen fixtures over the whole length.
Given the update to the OP, I have reduced my requested quantity. Thank you again Ronin42.
I would love to have 4 please, (2) 25 degree and (2) 36 degree if possible
Thank you so much! :slight_smile: :beer:
Edit: PM sent!
Gutting and rebuilding our kitchen. PM sent.
Need more projects where 25 Degree is OK.
Bump
ImA4Wheelr:
Your Nurmero Uno happy recipient.
Sent today
Alex Sorry to hear the PAR38 will not work for your project, but thanks for checking ahead of time.
Oh man! I so wish these were “regular” style GU24 bulbs! I have a ceiling fan that uses GU24 CFL’s and I’ve looked for LED replacement bulbs, but they are, indeed expensive. This is a wonderful gift you’re giving away. I wish my lights could use them.
David I know just enough to be dangerous about bulbs. How are these non standard GU24?
Could you be wishing they were PAR 30 instead of PAR 38?
Or “regular” E26, E27 thread in Edison?
Inquiring minds want to know
Yeah, I meant “regular” like Edison style screw-ins but with the GU24 base. What I have now is a light fixture that uses 4x CFL “twister” bulbs that have GU24 base. They are the size of a “regular” light bulb. What you have are what we call “can light” or “track” style bulbs.
My local home improvement store doesn’t carry any LED with GU24 base, only CFL. I looked online for them and I finally found some, but I didn’t have the funds to buy anyway. The bulbs you have (and even PAR30) would be way too big for my light fixture.
Awesome! Thank you Ronin42 :)
David no hard sell intended. I wanted to be clear for readers
The GU24 base does indeed fit your fixtures. What I think what we agree on is that the PAR38 is way to large for your fixture or aesthetics.
No worries and thanks
Yes, exactly that. Thanks for offering these to the community. I hope all your excess bulbs find their way into the hands of people who can use them.
Your customer #2
Boxes are in the post. :slight_smile:
Kewl, tnx! I’ll give them a good home. :slight_smile:
I can use (5) of them, all the narrow 25° type if possible. Thank you for doing this!
No worries
