I do like my sideswitch lights. But that is mainly because they have “silent” e switches. Much better for sneaking around than those loud clickies.
I used to prefer side e-switch lights.
The +:
Smaller (shorter) light design possible
Smarter firmwares and freedom in U.I. design
Almost silent activation (only fwd clickies are totally silent in momentary)
Maximum LED current not limited by switch
Now I prefer (fwd) clickies on my EDC lights:
The +:
Always easy-to-find switch that does’t accidentaly engage.
Easy to mod into an illuminated tailcap.
Can be used with gloves.
Too bad fwd clickies are very hard to find in small form factors.
The e-switch has more plusses, but the few plusses for a clicky still make me prefer them on smaller or “tactical” lights. For a size Q8 and up for around the house or camping use I prefer e-switch.
Since I have a lot to choose from, overall I think I use tailclickies about 90% of the time.
They can make plenty more sense if you tail stand a lot.
During black-outs for instance they’re real handy, or for any situation where you need overhead lighting such as working on something while you’re on your back - like under a car IOW.
And having both tail and side switch on a flashlight can be the best of both worlds - IOW. You know depending on the application IOW. So are they overrated IOW? Nah. Plus they’re still not even close yet to tail clickies in overall quantity of sales IOW so it’s not like they’re gonna eliminate tail clickies from production any time soon. So who cares IOW?
Maybe over-preferring vs overrated is the better thought here. IOW.
Oh and you forgot twisties Boaz! My first EDCs were all twisties. Nice & small.
But I can’t stand them nowadays :person_facepalming:
One thing I do like about most e switches is how silent they are, but I find the position of them useful as well.
No. They aren’t overrated.
I also like side switches on flashlights.
I like the side e-switches. The UI on my Q8 and D4 is awesome. I have a hard time wanting any light now that doesn’t work like that. And the tiny D4 is amazing. Sometimes I wish the D4 had a tail switch for lock-out, but then I remember how short it is, and just keep twisting the tail cap every time I put it in my pocket.
And I have to say, even though I can see the technical advantage of the e-switch circumventing the current limitation of a physical switch, I put off buying any emisars for a long time because I didn’t want something that likely to cause a fire in my pocket. But the UI is too compelling.
I don’t like side switches because I have a hard time finding the switch by feel alone, but even worse are lights with a tail on/off switch and a side switch to change modes. This forces me to change hand position when turning it on and then changing the modes using just 1 hand. When doing so the light inevitably shines away from what I’m trying to light up.
Of course this isn’t a problem using both hands and the forward clicky tail switch is a positive thing but not enough to balance out the negatives for me.
I can’t picture a Q8 with a tailswitch…
Depends on how you’re gonna use the light. Twisties are great for not accidentally lighting up the inside of your pocket but can be cumbersome to use one-handed, and can be annoying to switch modes. Sideswitch (e-switches) always have parasitic drain, unless it’s a dual-switch setup. Tailswitches are generally the noisiest of the bunch. With e-switches, you can get nice shortcuts to firefly, turbo, etc., even from off, plus ramping, etc., if programmed into the UI.
Each type has pros and cons. Depends on the function, the UI, etc.
Some of my lights wouldn’t have switches if they didn’t have side switches.
I like side switches if they are countersunk so that the light doesn't constantly turn on in the holsters. DX80 being the most guilty of this. Even with it in e-lock, a microbe could set that thing off in the holster.
Depends on the light. IMO side switches are more suited to mid-larger size lights and are better for navigating complex UI’s.
On smaller edc lights I prefer tail switch, ‘simples’
I like both. Just depends on the from factor of the light. Bigger head heavy lights benefit from a side switch I think. Keeps the light better balanced in your hand I think. I don’t understand the whole “I have to have a quite switch ” thing. I am getting ready to fire up a few hundred to a few thousand lumens. Why does it have to be silent? I can light up a whole room but damnit I don’t want you to hear my switch. Makes no sense to me, but, hey, to each their own. In some more complicated UI’s I find it easier to navigate and set options with a side switch. Tube lights, S2+ style, I like rear clicky’s.
For wide diameter/pistol grip/top handled type lights i’m not likely going to fit in a pocket I’d definitely want a side switch, Whereas pocket carried /vertical carried I’d go tail. If reaction time is important you’ll reach tail quicker because orientation isn’t as important imo. Whatever your application prefers ymmv
Being a light painting photographer I’m not a fan of side switches (at least for on/off) as they are not accessible when in the connectors between the flashlight and light painting tool. Give me a tail switch any day! Not a problem for larger lights used for illumination only such as the Q8 though.
I prefer side switches over tail switches because when you hold the flashlight normally your thumb is always right at the switch, without having to change your hand position to reach the back every time.
Easy to turn on/off or change modes.
Fumbling or dropping the light is easy when you’re trying to switch from one grip to another with a single hand just to press a button once.
It’s not hard to find a switch on the side of a flashlight because they are often made form a different material than the body, such as rubber, and also textured.
You can literally just grip the flashlight and immediately feel where the switch is.
The more options I build into my firmware,the more I appreciate e-switches. Meanwhile the UI is so feature rich that it can’t be used with a clicky anymore in a reasonable way.
I’m all for e-switches as they enable much better UIs.
But location is a separate matter. Tail e-switch:
- is harder and costlier to do
- takes more space
- may be less ergonomic in use
- but is easier to find initially
I’d like to have a light with a tail e-switch. But so far this is not enough to make my buy FW3A.
Klarus G20…?
