And 1 MT09R 35 high white (really silver) which already had the new TA driver installed and has calculated out to be a 1000 meter thrower. Using this exact light which is the first one I tested TA's new driver in I found a water tower 822 yards away and it was no problem at all. These are excellent throwers.
Unless you happen to want an emitter upgrade this light needs nothing and is ready to ship directly to the customer with the new driver installed of course Narsil that you all know about.
I Think I have 2 more of these I just have to locate them and order a driver from TA for them. That will be next week sometime when I do a quarterly inventory.
Until you actually see one of these throw, no picture or video can do it justice...
Got the MT09R on stock LED emitters, it is cooler than my 5700k MT03
Here are 2 pics to compare them.
The MT09R is doing super good with stock emitters and throws very well.
But MT03 just blast everything right in front of me much better.
Both are great. But if I must pick one I’ll pick the MT03…
Yea I took them at the different day. And yes the MT03 is a super good flood light. MT03 is 5700k and MT09R is stock NW emitter.
I will take pics on the same time maybe tomorrow night
Can it handle the power level of the MT09R though?
At 96% optical efficiency, it is going to be taking(0,04*19 000 lumens), it will be taking away 760 lumens, which isn’t insignificant. Can it handle the heat? Or am I wrong?
Also, guys, what kind of mods are you doing yourself? The reason I didn’t want any spring bypasses is that I’m going to replace the stock springs with phosphor bronze springs, as an example.
Any other soft mods that I could do to improve the light itself?
Hey guys I sold the MT09R 35 high CW White(Silver)
I normally always take Sunday off but I knew I had one more 35 high and all I needed to do was install TA's driver so I now have only 1 35 high left.
Black and even though the box is not marked for some odd reason I can just about bet the emitters are CW. 6400 lumen in my tube using 30q's
I am about to process the order for the white one and I will add this black one to the stores inventory when I do and at the same price.
Thanks for all of the support and please keep the pictures coming. love seeing them... That MT03 is 100 percent flood and extremely bright. I just like the extra distance from the 90R...
DC-Fix is not recommended for dedicated throwers since you want max concentrated hotspot, whereas DC-Fix will diffuse the beam. With that said, however, I think I remember reading someone saying you can cut a donut ring with the DC-FIX so it doesn’t affect the hotspot. I have no idea whether that works.
