No. The current design has waterproofing, which is probably not worth sacrificing for some tryptophobia-inducing aesthetic changes.
But why ?
Not a good look, costly, and compromises everything the tube is supposed to do. Bizzare idea.
Updated list : … Post moved to Page 111 . FW3A, a TLF/BLF EDC flashlight - SST-20 available, coupon codes public - #3305 by pepinfaxera
Reminds me a bit of the Thorens turntable I bought with money from my first real job. Replaced the original head with a light-weight version. And drilled a lot of vent-holes in it. All in the name of losing weight. The downside was that you needed to stay away when playing a record. Slip-stream, you know. The Thorens was not IP8, of course. But that did not matter, because it was not bought to be an EDC.
I agree it’s not that practical, but I think it just looks so good :slight_smile:
Can Andúril do a battery check (and nothing else of the blinkies) in lock out mode?
Would that a good feature?
Joe
Interested
I fancy one of these, put me on the list please.
Put me on the list also please. Thanks.
Updated list : … Post moved to Page 130 , FW3A, a TLF/BLF EDC flashlight - SST-20 available, coupon codes public - #3870 by pepinfaxera
Short list, Last requests .
[quote=Geuzzz]
With the inner tube design. It would be possible to bore some holes in the outer tube.
quote]
Little to far out of the BOX for some around here. Maybe in another light. I like it.
Please put me in for 2 lights. Thanks.
[quote=chadvone]
Drifting away from Fritz’s concept, pure engineering.
Edit: already compromised with the addition of the taper at the front.
Whatever floats your boat.
Lockout mode does only the following:
  • Momentary moon. Emitter comes on at the lowest level (ramp floor) while button is held, but stays off otherwise. Useful for quick tasks without unlocking.
  • Unlock. Click 4 times to exit lockout mode.
On items with a lighted button, it can also do this:
  • 3 clicks: Change button brightness for lockout mode.
  • Click, click, hold: Change button brightness for regular “off” mode.
I still fire up my Garrard 401, SME 3009, Quad IIs and KEF transmission line monitors when I want to hear proper sound.
It’s all been downhill since :wink:
I like it. It matches the muzzle brake on my AR-15.
I’m in for one please.
[quote=Tom Tom]
Agree that it’s not for this light. I am also torn between the original concept and the prototype with taper at the front.
I would be happy with either design.
[quote=chadvone]
I’m not torn. I didn’t like the minimalist first design. I do like the new design with a more aesthetically pleasing taper at the front. It makes a night-and-day difference to me. Then again, I don’t matter. I’m not on the list anyway. :stuck_out_tongue:
