SKV89
(SKV89)
May 12, 2018, 3:46pm
11
BlueSwordM:
Yeah.
If you really want to, just get the buck driver Lexel made for the MT09R XHP35.
Much more efficient than a FET light, and still has NarsilM.
Along with much lower moonlight.
For me I don’t really care about moonlight mode for throwers because they are only used for fun. I like a low moonlight for my small EDCs or even mega flooders that I can use as a lamp/lantern.
I want max power for throwers so I think FET may be more suitable but for XHP35, I wonder if it even makes a difference in max lumens. With that said, I do like Lexel’s buck driver. On the MF01 he modded for me, the startup lumens holdup pretty well even on partially depleted batteries.
How many people are in yet?
I would love to know.
Newlumen
(Newlumen)
May 13, 2018, 1:19am
13
I am debating if i should get one in xhp35. My plan is to get a TA driver and upgrade xhp35 hi.
Since you already have an XHP70.2 light, just get the XHP35HI version. At NW, it comes in at 5000k and 80CRI apparently.
M4D_M4X
(M4D M4X)
May 13, 2018, 4:32am
15
only a third of the goal is reached... :(
Anyone know how well the HI version throws? Not seen any reviews of that led version.
Seems to throw very well.
Having an XHP35 HI with that size of reflector, as the reflector is about as deep as the Acebeam K70. Even at only 2500 lumens, 1200m throw is a reasonable claim.
Edit: I was perhaps wrong.
MT07S HI:
1600~1800 lumen and 220 kcd
Friday night we tested my MT09R XHP35 Hi from this GB and a Haikelite MT07s. The MT07s has a bit higher range, but the beam of the MT09R is much wider.
My luxmeter shows 220.000 candela for MT07s and 196.500 candela (MT09R:6meter, Sony VTC6) for my MT09R (NW, but it looks like CW).
Our second luxmeter shows 27% more candela ! But my luxmeter compared with many other luxmeter and shows the same candela for many other flashlights like other TLF users had detected.
For example:
Astrolux MF02NW:…
M4D_M4X
(M4D M4X)
May 13, 2018, 3:44pm
20
Newlumen:
We need 67 ?
~60 more participants needed
Yohan110
(Yohan110)
May 17, 2018, 11:39pm
25
How noticeable in real world use would the ~350m FL1 difference between the Astrolux MF02 and the Haikelite MT07S HI be?
That is a non negligible difference.
The MT07S HI does have a slightly better UI, and more thermal mass, so it’ll stay a bit cooler than the MF02.
But at 1050m tested throw vs 1400m tested throw, if you only want throw, get the MF02.
DENGOH
(DENGOH)
May 18, 2018, 12:20am
27
Are you referring to manufacturer published number of 1587m and 1200m for MF02 and MT07S HI?
Yohan110
(Yohan110)
May 18, 2018, 1:25am
28
I was refering to the tests in this link posted above by hIKARInoob.
Yohan110
(Yohan110)
May 18, 2018, 1:28am
29
BlueSwordM:
Thanks, I think I will pass this up and get the MF02 instead.
