I finally received this light after almost two month waiting. Packed inside a thin zip pouch wrapped with some film, all inside a simple bubble envelop. A terrible petroleum smell was all over it and the packaging felt a bit sticky. Even after washing my hands twice i could still smell it!
There is a small gap between the head and the body. Not that much really… but you can see the brass from the pill.
Nice and compact SS light.
I tried it on a regular AA cell. Not bad.
Now i’m scared to try a 14500…
There is a marking on the driver that i remember having seen elsewhere: AIRAYLAND.
Is it really 14500 capable?
Been running a 14500 in mine since I got it. Over a month ago I think. I use it daily. Never even a hiccup out of it. You’re right though. The packaging was kind of, well, different. Mine as well has a small gap between head and body. Must just be the design of it. Never tried an alky or nimh in mine so not real sure on the difference in output. I’ll charge up a eneloop and take a gander at it. I love the thing. Was thinking of getting a few more.
If mine ever comes, I’m afraid of using 14500 now after hearing about the failures. Even if CS is good, it will take 2 months to get parts or replacement.
It arrived yesterday, 8 weeks to the day. The package was a simple mailing envelope with the light in a baggie wrapped in tape . It smelled like some kind of penetrating oil .
The light is very nice . Attractive styling . Rosie tint. Compact but heavy.
I emailed Jacky to ask if 14500 was compatible . He got right back and said it was but cautioned it has no stepdown so it will get hot.
Tried AA first . OK simple UI with L,M,H . Low is not ML which for me is better. Next tried 14500 and everything went well so far. Only put it on high for short while.
Overall I give this light a thumbs up . Would make a nice gift light . I will EDC it for a while and see how it lasts. Not sure if it is easy to get into for modding. Hopefully someone more experienced in that will give us a report.
Hmmm. I don’t think the reason it dies on 14500 is due to heat from no stepdown. I only put 14500 in to do a ceiling bounce test and it died literally within a few seconds. While it worked, it was much brighter on 14500 than AA though so it would be a great EDC with 14500 if it works reliably.
I posted my results here so you can compare it with other AA lights too.
Got my little 18500 Brass Beauty in the mail today, 3 weeks to my door from Enogear. Not too bad.
Promptly pulled the XM-L2 and 7135 chip driver and put an FET+1 Bistro driver with an XP-L V3 3A HI emitter… on an Efest 18500 1000mAh cell it does 1211 lumens in Turbo.
I always though that there was a typing mistake and that this was a 18650 light, not 18500 :person_facepalming:
So…how hard would be to mod it Dale? :smiling_imp:
Mind posting any thing on its “entrails”, please? :innocent:
It has a brass pill threaded into the head much like a Convoy S2 (the old style, without the integrated emitter shelf), simple enough to bump the existing driver with a couple of 7135 chips or swap it out with an FET+1 style driver like the X6 Bistro. (which is what I did) I also swapped in an XP-L V3 3A HI on a Noctigon. Basic stuff, not all that difficult to do.
Edit: FWIW, I didn’t put a spring on the Bistro driver but instead built up the pad with solder just enough for the cell to make contact without the retaining ring impeding it. This allows the 18500 to fit inside, don’t think a button top cell would allow the tail cap to go on fully. Would probably still work as everything here is brass so ground is good with first contact of the threads.
There is a white plastic insulation disc in the tail cap to isolate the switch and there is a white plastic centering ring for the aluminum reflector, other than the glass lens and the o-rings everything else is brass. Everything! Even the button to turn the light on/off. My wife has had a DQG Brass Beauty in her purse for years, this one is EXACTLY the same except the battery tube is shorter and doesn’t have flats cut on it’s side. The heads match up perfectly as do the tail caps.
For what you say it wouldn’t be an hard mod! (so it seems)
Gonna keep this in mind as that light is gorgeaus
Also, if I perceived well the pill doesn’t have a shelf? I thought the S2 pills were like the S2+ only being shorter.
In any case DTP MCPCB (noctigon or not) are recommended to allow the led to light up according to the driver’s power!
Thanks again for the explanation Dale
This DQG has a threaded in pill, I guess the S2+ also has a pill as I got a copper one from Hoop for this light, so yeah, it’s kinda like that. Or a Sinner EDC.
Yes, the brass pill has a stepped shelf for the MCPCB, a 16mm Noctigon fits right in. I never allow an aluminum MCPCB to stay in a light, never. I have over 100 20mm SinkPAD’s here, I’ll make one of those fit if I don’t have the right board. lol
I have another sheet that is more complete factory wise that I’m saving out, not planning to use. And at least a sheet’s worth on my bench, some on a sheet and some already broken down…
I was on friendly terms with the Lady at SinkPAD when they switched over from their original to the SinkPADII version, I bought 200 of the old ones, the last they had in stock.
I could be wrong but I suspect these are not brass but instead, bronze. See how the old one hasn’t blackened with age? No special care, it sits in my wife’s purse and get’s used whenever she needs a light. She’s also got a tiny little Olight Titanium in her purse as well as a blue Emisar D4.
She likes to tell the story of a late night leaving the hospital when a couple of Security Guards were trying to assist a Nurse who’d locked her keys in the car. They were trying to shine their light through tinted windows in an attempt to locate said keys inside the car but were having difficulty getting enough light inside to see. My wife offered up the Brass Beauty and they were like, “It’s ok ma’am, we’ve got this, you’re little light wouldn’t be much help anyway.” Then she turned it on and put it up against the glass and they were amazed! lol Spotted the keys on the floor in front of the seat where the Nurse had dropped them in getting out of the car…
Always a nice story to show how “flashaholics’ lights” are not “little lights” :smiling_imp:
Hum, now it’s me who’s getting leaned towards that Beauty!! I won’t be hard to mod it at all if the pill is like the S2+. MTN drivers will fit on that one for sure, with guppy3drv, it will be a nice light
A Luxeon V (4000K) can also be a good choice for the emitter.
A long list of desired lights, a short list on the bank account though :person_facepalming:
Thanks Dale :+1:
I have 0.5mm threads and just got through cutting some 0.75mm that are pretty fine, tiny works, lol.
I think these are 0.75mm, without measuring. It allows for a short piece of threaded attachment while still catching 6 or 7 threads. You can’t afford to mess up any threads though…
