Will the lantern require button top cells? I just recently realized the BLF Q8 does, and since this lantern is using may identical parts, I am suspecting it will also?
DBSARā¦ I donāt know how important it is, but my total should be ā5ā.
Thank youā¦ā¦
502 g_sintornillos 503 teacher 504 teacher
505 Kodachrome40
Most likely as the four cells are in parallel and button tops are required to contact the positive driver ring when threading the battery tube on the head.
sorry i fixed that its easier i put the total number after the last list request then it is to move every one else down. Either way Thorfire has expressed lots of interest in this project as it approaches 1000 lanterns interested.
I am adding the base tripod threaded mod tomorrow to the prototype, and will do some beam-pattern ( beam shot) comparisons between the new V2 versus the V1 and some other modified lanterns i have. So far the V2 is very impressive with the new head design, with a smoother, wider field of illumination than any other lantern i tested or have, with the least lantern glare effect of them all. I can;t wait to field-test this (with photos) on our first 3-day camping trip in 2 weeks. I hope to get the USB TP4056 based charging circuit added to if i can in time, to test its off-grid sustainability using a 10-Watt Eceen folding solar charger.
The āheadā of this light (as well the Q8) is MOST of the cost. The only thing left is the battery tube. Others have suggested earlier in the thread that it would be nice to have a diffuser that connects over the stock LEDs in the Q8, but that is not anything like what is being created here. Now, it has been confirmed that there is also planned a threaded hole in the base for tripod mount. The Q8 doesnāt have that either. At this point, there is no part of this light that isnāt āchangedā from the Q8 design somehow, even though the parts will be made from the Q8 CAD drawings, so they will likely be able to āLegoā together. As such, the likelihood of this being made as just an add-on to the Q8 is probably less than zero.
You are on the interest list Phlipp, number 757. I am assisting DBSAR in keeping this list updated, and have created a google doc for it. You can see the list at this link anytime. I will be sending DBSAR an update periodically so he can update the list in the first post as well.
