I like both. Just depends on the from factor of the light. Bigger head heavy lights benefit from a side switch I think. Keeps the light better balanced in your hand I think. I don’t understand the whole “I have to have a quite switch ” thing. I am getting ready to fire up a few hundred to a few thousand lumens. Why does it have to be silent? I can light up a whole room but damnit I don’t want you to hear my switch. Makes no sense to me, but, hey, to each their own. In some more complicated UI’s I find it easier to navigate and set options with a side switch. Tube lights, S2+ style, I like rear clicky’s.
For wide diameter/pistol grip/top handled type lights i’m not likely going to fit in a pocket I’d definitely want a side switch, Whereas pocket carried /vertical carried I’d go tail. If reaction time is important you’ll reach tail quicker because orientation isn’t as important imo. Whatever your application prefers ymmv
Being a light painting photographer I’m not a fan of side switches (at least for on/off) as they are not accessible when in the connectors between the flashlight and light painting tool. Give me a tail switch any day! Not a problem for larger lights used for illumination only such as the Q8 though.
I prefer side switches over tail switches because when you hold the flashlight normally your thumb is always right at the switch, without having to change your hand position to reach the back every time.
Easy to turn on/off or change modes.
Fumbling or dropping the light is easy when you’re trying to switch from one grip to another with a single hand just to press a button once.
It’s not hard to find a switch on the side of a flashlight because they are often made form a different material than the body, such as rubber, and also textured.
You can literally just grip the flashlight and immediately feel where the switch is.
The more options I build into my firmware,the more I appreciate e-switches. Meanwhile the UI is so feature rich that it can’t be used with a clicky anymore in a reasonable way.
Thanks pinkpanda3310, that’s interesting. I think I’ll take a closer look at a later date. Which means “look and read” rather than “buy”, I’m not into flooders unless they are tiny and this one is too not interesting enough to make me reach to the pocket.
I’m slowly changing over all the lights to Side sw.
Tail switches annoy me no end.
You lot will also find. As you get older and your thumbs aren’t so flexible. Tail switches often take several grips on the bloody torch to get the angles right to operate the things.
Side switches. 30–100 are ideal outside. with 2–30–100% for inside.
ANY flashes do nothing but annoy me.
ALL torches should have the 1\4 turn tail cap to isolate the battery. and twisties I find are the best for thoce tiny little ones.
^THIS^ +1,000,000……infinitum…. Aging hands are definitely a factor. Burning, Stinging, pangs that can shoot from hand/wrist/finger joints to the bowels of hell in a split second. I have both configurations of switches…side switches eliminate the pain though…. Getting older can suck …. :disappointed:
Just because a switch is on the side does not mean it needs to be an e-switch.
This topic is not about e switches vs physical switches, it is about tail vs side.
Also if the light is designed well then it takes the same amount of time to find a side switch as it does a tail switch, assuming you have working nerves in your fingers.
