Thank you DBSAR!!! I am looking forward to this……
Please add me for one more (total of 4)
Thanks
I am adding the base tripod threaded mod tomorrow to the prototype, and will do some beam-pattern ( beam shot) comparisons between the new V2 versus the V1 and some other modified lanterns i have. So far the V2 is very impressive with the new head design, with a smoother, wider field of illumination than any other lantern i tested or have, with the least lantern glare effect of them all. I can;t wait to field-test this (with photos) on our first 3-day camping trip in 2 weeks. I hope to get the USB TP4056 based charging circuit added to if i can in time, to test its off-grid sustainability using a 10-Watt Eceen folding solar charger.
Wow!!! Like I mentioned above… it just keeps getting better & better. :+1:
Thanks for the info……
Interested, it would be great if this lantern-head could be bought separately as an add-on to my Q8.
Put me down for one if possible please
Please add me for a 2nd. 2 total. I am #518 on the list already.
Thanks
Please put me down for 2. Great idea and lots of great R&D….
The ‘head’ of this light (as well the Q8) is MOST of the cost. The only thing left is the battery tube. Others have suggested earlier in the thread that it would be nice to have a diffuser that connects over the stock LEDs in the Q8, but that is not anything like what is being created here. Now, it has been confirmed that there is also planned a threaded hole in the base for tripod mount. The Q8 doesn’t have that either. At this point, there is no part of this light that isn’t ‘changed’ from the Q8 design somehow, even though the parts will be made from the Q8 CAD drawings, so they will likely be able to ‘Lego’ together. As such, the likelihood of this being made as just an add-on to the Q8 is probably less than zero.
Im interested too. Pls put me on the list for one
You are on the interest list Phlipp, number 757. I am assisting DBSAR in keeping this list updated, and have created a google doc for it. You can see the list at this link anytime. I will be sending DBSAR an update periodically so he can update the list in the first post as well.
Moin Moin
Pls put me on the list for 2x on top.
Regards
Jens
Moin Moin
Regards
Jens
Done, #s 758 and 759. looks like 4 total for you so far.
Just checking back in to see where the project is.
I’m on No.183 please add me 1 more total 2…thanks
You presently have 2 entries in the list, 183 and 233. Guessing this satisfies your needs, let me know if you want to add beyond that.
I checked the list and can’t find my name. My post Can you put me in for 1 please? 1 total…
list updated, you’re in the list at # 760
Edit: The link above had a problem, it is fixed above and you can use this link as well to check if/where you are on the list.
Please add me to the list.
