Here is perfect example of beam profile Im looking for:
He said thrunite in the video, reviewing what they had for sale then, and the shape of the head, i’d say maybe the TN40?
It was a TN40, listed in the information under the video, if you click on additional.
That’s a TN40 in the video, so that’s an option for you. I could tell by the shape of its head, and the petal pattern of the spill in the video.
If you want a single emitter thrower, the Acebeam K65 with an XHP70.2 dedomed will have similar performance to the TN40, but with slightly more lumens and lightly less throw.
You can also look into Vinh’s lights at Skylumen. He has a version of the TN40 where he uses XHP35 HI emitters instead of XPL HIs. (9000 lumen/520kcd vs 4800 lumen/345kcd.)
Skylumen also has a version of the Thrunite TN42 where he puts a Luminus CFT90 LED in it to get 5000 lumen and 1m kcd.
Indeed it is TN40 in the video, and the beamshots look very impresive. I am just wondering if there are other interesting multi emitter options for example from Nitecore or perhaps a single XHP70.2 apart from K65.
Nitecore multi Emitter lights are very expensive
Jetbeam T6 with XPL HI or sliced emitters would be nice
Some cheaper alternatives may be the Black Shadow Terminator, Solarforce SP-03, and then the Nitecore TM16 also is nice but pricier. I put 3 SST-40’s in my SP-03 (and some tricks in the driver department) and it’s making close to 8000 lumens with a great spot and spill. Similarly the Terminator does well with more modern emitters like the XP-L HI or a set of de-domed XM-L2 U4’s.
TN40S with my driver and XHP35s is also nice
The Solarstorm SP03 is around 3000 lumens stock, for about $80 at FastTech
The nice thing is the size of the individual reflectors, sort of a revision of the BTU Shocker, each reflector is almost C8 sized. It also has a handle for ease of carry and uses 4 parallel 18650’s.
The handle can be removed and the light used in standard format, doesn’t upset the e-switch use or it’s water ingress protection.
I’m actually using ToyKeeper’s Anduril in mine so it has lightning mode and candlelight, as well as useful strobes that can be set as to speed as well as a beacon that is also configurable. Thermal protection too can be set as well as the initial ambient reading. Really makes the SP-03 a modern useful flashlight that suits a wide set of needs.
Edit: Should also say that the SP-03 is more compact than it may seem, shorter than an L2 with a head diameter only slightly larger than a Courui D01 Fathead.
The Black Shadow Terminator makes about 3500 lumens from 4 XM-L2 emitters, 4 18650 cells in parallel and sells for around $100 also at FastTech.
This one has the switch in the handle though, so removal of the handle isn’t as desirable.
For now I have excluded Nitecore TM series, due to rather high price and only CW light tint. Can someone, preferably Thrunite and acebeam owners fill me in on their NW tints? I saw lot of K65 videos, where the light from dedomed XHP70.2 looked somewhat greenish…
You’re always going to get a green tint from a dedomed Cree led. No matter the manufacturer, you will be subject to the tint lottery of Cree LEDs if they use a Cree LED. It comes down more to the specific LED in the light than the manufacturer of the light.
The XHP35 HI for the most part though seems to have rather decent tints in the 4500k range. I haven’t read too many stories of grossly green 35 HIs compared to 70.2s or XPLs. I’m not sure who sells a multi emitter NW XHP35 HI light stock, but I imagine it will be expensive. You can get someone to mod those emitters into a host of your choice as well, but that too will be expensive.
Acebeam X45
twisted raven, with his 21 posts, decisively states “You’re always going to get a green tint from a dedomed Cree led. No matter the manufacturer, you will be subject to the tint lottery of Cree LEDs if they use a Cree LED.”
Which of course isn’t exactly the truth of the matter. Do this a few hundred times and you’ll see, there are good tints from clean de-domes. It’s not easy, not reliably accurate to pick the right emitter, but it does happen. Which is why MaxToch de-domed for stock lights in the Shooter 2X. And didn’t the Olight M2X-UT also come with a factory de-domed emitter? It happens, it’s just not easy sometimes. Wish I had a dollar for every Cree emitter I’ve used, or for every one I’ve removed the dome from….
What does my 21 posts have to do with anything? This isn’t the main flashlight forum I frequent. That just comes off as rude and insulting.
I’m also a tint snob by nature, so I’m very sensitive to green bias in LEDs. Even the best cherry picked dedome jobs I’ve seen or used look slightly green— whether they’re from a manufacturer or from an individual modder.
Budget aside and apart from the “tint lotery” which one would YOU guys go for? Acebeam K65 or TN40S? Why and which tint would you choose?
Well, you’re stating unequivocably that if it’s a Cree it’s a gamble and that’s just not so. I’ve built hundreds of de-domed lights, what you’re saying is not true and it’s misleading to everyone else that is new here and taking what your’e saying like it’s gospel. With 21 posts here you have to admit, there’s no credibility for experience. Otherwise known as noob, whether you are or not is completely unknown but you are HERE.
So you can come in and call my years of experience a lie, and that’s not rude and insulting? Geesh. Noobs.
When did I ever specifically call your years of experience a lie? Get off your confrontational attitude.
You show me a dedomed light with an amazing tint and I’ll shut myself up. Compare it to a stock XHP35 HI or Nichia light. In fact I would gladly buy one from you if you could produce a dedomed 70.2 that wasn’t greenish. Until then I will continue to tell others what I believe to be true with all dedome jobs I’ve come across, as I feel it’s safer to them to let them know a dedome will result in slight shift to green.
As for the topic at hand,
With regarding tint, one of the benefits of dedoming is that you will get less tint shift within the beam, since flat emitters interact with reflectors differently than domed ones. In general I consider this to be more pleasing than something that’s very greenish in the corona and purplish in the spill.
I also feel you should go with the TN40S, since it’s pretty much what you wanted based on the video you linked. I’ve not used the K65 myself, but from what I’ve seen of it makes it look rather yellow-greenish.
As for the attitude, sorry about that, indeed my bad.
Not everyone is a tint snob, a lot of people like a blue white beam and some even like a green hue. We have literally thousands of new people here, stating something as an opinion and making it sound unequivocable is misleading to the many new people.
I like the tn40s or the Jetbeam t6. The spo3 is nice when modded. I kinda regret selling that light now after hearing what dale did to his. Those sst40 made a huge difference! Mine was only doin close to 4000 and it was modified.
I also like the convoy l6 with smo reflector modded with new driver and 70.2.
