I’m slowly changing over all the lights to Side sw.
Tail switches annoy me no end.
You lot will also find. As you get older and your thumbs aren’t so flexible. Tail switches often take several grips on the bloody torch to get the angles right to operate the things.
Side switches. 30–100 are ideal outside. with 2–30–100% for inside.
ANY flashes do nothing but annoy me.
ALL torches should have the 1\4 turn tail cap to isolate the battery. and twisties I find are the best for thoce tiny little ones.
^THIS^ +1,000,000……infinitum…. Aging hands are definitely a factor. Burning, Stinging, pangs that can shoot from hand/wrist/finger joints to the bowels of hell in a split second. I have both configurations of switches…side switches eliminate the pain though…. Getting older can suck …. :disappointed:
Just because a switch is on the side does not mean it needs to be an e-switch.
This topic is not about e switches vs physical switches, it is about tail vs side.
Also if the light is designed well then it takes the same amount of time to find a side switch as it does a tail switch, assuming you have working nerves in your fingers.
I actually really like both types, depending on how they are implemented. There is no guarantee you won’t have problems with either kind of switch…but electronic switches should be less likely to fail, if they are made properly. Clickies wear out, no matter what.
I’m a fan of the side switch. They mean small lights. which I am a fan of. Plus, they can be used in many positions with various fingers and I find that useful. Generally, a tailcap switch is a thumb only operation.
Depends on application, key ring for me has to be twisty, side switch for general uses. I find side switch more comfortable , the switch is just there when using it. Not always easy to find though when dark and quickly grabbing. Rear clicky for me is more suited when holding the flashlight at head height(side clicky for waste height). I like all types of UI, all have pro/cons depending on use. I would say most of my uses are more toward side clicky overall……
