Soon.
Nitecore Concept 1 showing active in OP, but the code is expired.
Will get it reactivated soon.
New update for JM70 1km. Any interest?
price for JM70?
Retail price is about $59 for XP-L HI.
Is this a new version ? Mine doesn’t have a charge port nor a black bezel…
I hope they changed the UI…
I`m interested if Amutorch eleminated the donut hole (my one with the blue bezel has a really dark donut hole…)
I would love a XHP35 Hi version…
interested in nitecore tm03, coupon please
Does it use an xpl hi?
I’m surprised you’re seeing a donut hole. It may be caused by the reflector being too close or too far away from the emitter. You might be able to tweak it yourself to eliminate that dark center.
Interested in DX80
Hi JasonWW,
Yes, my version has an XP-L Hi LED.
I will try to open the torch and fix it…
Thanks
Carsten
So ? Did they change the UI ?
Out of stock. [quote=cyrex] interested in nitecore tm03, coupon please [/quote]
Interested in the code for the uni-t ut210E, the clampmeter.
Thank you.
I`m interested in the UNI-T UT210E
Thanks freeme!
Help yourself. https://freedailydeals.org/2017/04/26/group-buy-uni-t-ut210e-multifunction-acdc-current-mini-digital-clamp-ampmeter/
I`m interested in the UNI-T UT210E Thanks freeme!
interested in a decent headlamp
The Boruit D10 is the best bargain headlamp at about $10-$12.
Hi Freeme,
I tried to use your code for the Concept 1 but it wouldn't work. The one that is linked to Gearbest is "discontinued". If I try to use the code with the Concept 1 I find when I look for at Gearbest will not work. Can you please help me?
Thank you!
