Dale, the single cell light I’m modding isn’t a C8, but it is an old favorite, an original UltraFire HD2010, which already has pretty amazing throw for having an outdated emitter (XML T6) with east-092 driver (DD but crappy mode arrangement)
I have one of these copper pills:
Takes up to a 26mm MCPCB, and a 22mm linear/FET driver.
I plan to use a Maxtoch XP 26mm Copper MCPCB to keep the wires away from shorting on the reflector.
And yes throw isn’t everything in my plans for it, I want good throw, but with some useful spill / larger hot spot / extra output.
It’s one of my favorite lights and one of my first purchases when I got into this, and I’d like to make it into something special and useful, so I thought it would be a good candidate for an XHP35 HI, don’t want to derail too much here but I’d love to hear any other suggestions.
I’m also considering an XP-L2 HD (dome on) I have a few (stock) lights equipped with it and the tint looks fine to me.
I’d use an FET driver from Richard paired with an SST-40, I think. That is a good combination for this C8+ or the HD2010 either one, where the parameters are as you outlined. I think I’d use thermal paste to begin with, try it out, and if the spot was too large I’d pull the pill and remove the emitter then slice/dice/shave the SST-40. Would probably re-flow the emitter/mcpcb into the pill then, might would reinstall it with thermal paste and double check first but I’d probably go straight to the re-flow. (test it first, make sure it isn’t ringy and that it’s to your satisfaction, then go from there.)
Versus using only thermal paste, what does reflowing the mcpcb to the pill result in? Better heat dissipation?
I had thought about the SST40 but wasn’t sure I’d be okay with the tint since I’m pretty firm on neutral tints only, and everyone seems to comment on how cold/bluish it is, interestingly just today I received my first SST40 light! (Jetbeam E20R). I wasn’t able to get outside with it tonight but inside it’s not too horrible, I don’t see any bluish tint at all, even on white walls, it looks very yellowish to me, with a hint of green.
I also plan to get the C8+ tan host version and run a MTN-17DDm so maybe the SST40 for it as well. I see Richard offers the Slice LED option, how’s the tint on it after slicing?
The SST-40 doesn’t exhibit the tint shift we’re used to seeing from Cree, it does drop some but not like the XM-L2’s. I’ve found the 40 to have a nice creamy color once the dome is taken off. Richard seals them though, so it’s a bit different than a naked die.
Gnude Gnu’s haven’t been legalized for power use to date, not in the US anyway. Testing is underway to put them to work under AR confinement but the results are not in… Gnarly Gnude Gnu’s will be next. Mark my words.
Still though, it’s true, the XM-L2 U4 with a clean de-dome on it throws further and burns less current than a pushed XP-L HI, MaxToch found that out in the Shooter 2X.
The Convoy store also claims “about 1100 lumens”, so it might be true. The output current is listed at 3000mA, which is higher than the previous Convoys that use 8x7135. So, it looks like they’re using a better driver.
If I had to guess, I’d say probably closer to 1000 lumens, but I wouldn’t rule out 1100.
