Gnude Gnu’s haven’t been legalized for power use to date, not in the US anyway. Testing is underway to put them to work under AR confinement but the results are not in… Gnarly Gnude Gnu’s will be next. Mark my words.
Still though, it’s true, the XM-L2 U4 with a clean de-dome on it throws further and burns less current than a pushed XP-L HI, MaxToch found that out in the Shooter 2X.
The Convoy store also claims “about 1100 lumens”, so it might be true. The output current is listed at 3000mA, which is higher than the previous Convoys that use 8x7135. So, it looks like they’re using a better driver.
If I had to guess, I’d say probably closer to 1000 lumens, but I wouldn’t rule out 1100.
Pretty sure the driver is made up consisting of 8x380mA 7135 chips, making it effectively a QLite (3.04A) So actual output depends greatly on the emitter choice you make when you order the light. A 1A tint will be higher than a 4C, for example. Just how it is. Relatively simple to stack a few chips for more power.
Where are you referring to that it says this? I haven’t seen that info anywhere. As far as I know this is still the 2.8A driver and would not be putting out 1100 lumens. Am I missing something? I can see BG listing 1100 lumens but I don’t see anything like this in the Convoy store.
I got a tad over 700 lumens out of the box… maybe closer to 800 (log is at home). With a freshly charged 30Q. I replaced the driver with a blf a6 one and swapped emitter with a sliced SST40. Now it’s making just over 1600. Perfect light now.
