Very late look at the Zanflare F4
44 posts / 0 new
DB Custom
DB Custom's picture
Last seen: 3 hours 17 min ago
I was asked a while back to do a review on the Zanflare F4 4 headed beasty and I kinda dropped the ball on it. I got a good start measuring output and such and then ran into some issues personally and never got back on it. Sorry about that.
So I’m gonna get this started on this with an introduction and will come back and flesh it out as I can.
Gearbest’s pics…
And a quick one of my own…
This is a very interesting light from Zanflare, with 4 heads in a similar fashion to the Black Shadow Terminator but each head can rotate down to a 90º angle independtly, and each head can be turned on/off! The electronics are elaborate in this light with an Oled window showing which of the LED’s are operational, what level of 5 is being used, how many lumens, how much time is left at that output, the current battery level (4 parallel 18650’s) and even the temperature. Built in charging through a micro USB port as well.
I took output readings in all the variations and it is very flexible, I got from 20 lumens to 3560.4 lumens , that’s from one emitter at level one to all 4 at level 5… here’s a quick breakdown of these 20 levels as seen on Sony VTC6 cells….
…………………..1 head……………..2 heads……………..3 heads…………4 heads
Level 1……….20.25 Lum…………39.26 Lum………….56.24 Lum………..75.90 Lum
Level 2……….89.70 Lum………..169.05 Lum………..244.61 Lum……….334.65 Lum
Level 3……..519.60 Lum………..952.20 Lum……….1397.25 Lum……..1928.55 Lum
Level 4……..786.60 Lum………1518.00 Lum……….2208.00 Lum……..2932.50 Lum
Level 5……..966.00 Lum………1825.05 Lum……….2697.90 Lum……..3560.40 Lum
I can see where this might be an excellent light for an outdoorsman, camping or hiking, with the ability to direct light to either side and in front of you while walking while also keeping one head aimed further out for a preview of what’s coming. Also in strobe or beacon modes the heads can be flared out to the sides for a 360º coverage to indicate where one is if in trouble.
I will get some better pictures and some beam shots as soon as I can, will be back to flesh this out some more… This is a very complex light and I intend to try to represent all it does, please bear with me!
DB Custom
DB Custom's picture
Reserved for pics
Found the User Manual Big Smile
And the box…
Wanted to say this light uses 4 Cree XP-L HD emitters (domed) that are nearly pure white in tint, I don’t have the specs on what was used in this but the choice was an excellent one. Wink
Due to the style of the driver battery contact, button top cells are needed or at the very least solder blobs, this is because of the Q8 style contact board.
So, you turn it on with the center button. Each of the 4 arrows controls the on/off selectability of the independent heads. The display shows which of the 4 were turned off (or on) Press the center switch and hold briefly to turn off. Press the center switch AND the lower arrow simultaneously and hold to lock out. Lock out status will display briefly in the window. If you attempt to turn it on when it’s locked out, the display will light and indicate Lockout.
When off, a double click on the center switch enters strobe, a click moves through SOS and beacon modes. The selectability of the heads is active when in the blinky modes so one through four can be selected for brightness levels.
Opposite the switch panel there is a tripod mount, which should come in quite handy. Very cleverly machined into the lip of the tail section are two oblong slots for a lanyard to attach. I suppose an enterprising individual could use these slots to suspend the light from a fishing swivel and have quite a light show in a large tent… Wink
Edit: A look at the OLED screen showing values when operating the light…
Firelight2
Firelight2's picture
Last seen: 47 min 49 sec ago
Wow! Impressive looking light.
It looks like it should have a built-in motor to make the head spin around to truly turn disco mode into DISCO mode! Crown
DB Custom
DB Custom's picture
I know, Right? My 10 year old got ahold of it and immediately spread the heads, pointed it down, and brought the “mother ship” in for a landing while slowly rotating it. Had to laugh!
MRsDNF
MRsDNF's picture
Last seen: 4 hours 6 min ago
Thanks for the rview Dale. How is the power going to each individual head? I’m assuming wires but could be through contact.
tatasal
Last seen: 17 min 26 sec ago
Can you furnish details on where this light can be found?
Strange it’s not the Gearbest’s website Sad
ivyatsw
ivyatsw's picture
Last seen: 8 months 1 week ago
In fact, it looks very cool from the picture.
Brightify to brighten your life!
beam0
beam0's picture
Thanks for the review! I didn’t know it even existed and it’s so awesome!
Double duty… from searchlight to 360 degree area light/lantern (campsite table lamp!)
But for me lights of this form need a handle, hoping there is a tripod mount on the other side somewhere to work with a handle mod.
"Over 2000000 hours (about 200 years) standby time"  (DQG Tiny 4th)
"27,157 results for zoomable flashlight" (ebay)
DB Custom
DB Custom's picture
There is indeed a tripod mount opposite the switch set. Wink
tatasal
Very refreshing and useful design actually…but where can we find this?
DB Custom
DB Custom's picture
It’s a Zanflare, which makes it Gearbest’s baby. This is a sample light or a prototype, they should be coming out with it soon…
toddcshoe
toddcshoe's picture
Last seen: 1 hour 49 min ago
Very cool. Did they mention a MSRP? I could find many uses for a light like that at a campsite or working on a piece of equipment in low light. Also, with all 4 heads fired up on level 5. What is the beam like. Is it Q8’ish?
lumenzilla
lumenzilla's picture
Last seen: 21 hours 19 min ago
It looks cool in picture but dunno if I could find the benefit of four different tilt-able LEDs Big Smile
DB Custom
DB Custom's picture
todd, the beam is tighter than a Q8, more along the lines of the Terminator as it much resembles that light when all 4 heads are front and center.
freeme
freeme's picture
Last seen: 14 hours 25 min ago
Design is really out of this world. surprised
DB Custom
DB Custom's picture
I found it pretty odd, at first, but I can see after using it a while that it could well have it’s uses and become indispensable. Don’t think there’s anything else like it out there.
djozz
djozz's picture
Last seen: 51 min 45 sec ago
That is a fun light! They missed an opportunity to make a strobe that circles around the 4 heads. Make it an RGBW light would be fun too.
strayz
Last seen: 9 hours 56 min ago
The only thing I can think that would be a useful add on would be a rare earth magnet. To use under the hood of a car, r any other place you might want to hang up a light. Yes I know 3000+ LM is a bit over kill for under the hood, but I am thinking run time would be nice and long at lower levels.
DavidEF
DavidEF's picture
Last seen: 3 hours 55 min ago
Well, it would have to be a very large magnet to hold this thing up. Even a strong Neodymium magnet would need to be fairly large for a tail-cap magnet. Then you’d have the opposite problem – how to get it down. The magnet would be strong enough to give you some real trouble when trying to remove it from any ferrous metal surface.
Reason is not automatic. Those who deny it cannot be conquered by it. Do not count on them. Leave them alone.
-Ayn Rand
DB Custom
DB Custom's picture
Added a video at the end of post 2 showing the OLED display screen during operation. It’s pretty elaborate what all it shows, fairly cool….
Adding it here too just because…
blueb8llz
Last seen: 6 min 34 sec ago
One of the more unique lights of the decade. But unique doesn’t always mean good haha.
Looking forward to rest of review. They should have made it Bluetooth compatible hehe
Newlumen
Newlumen's picture
Last seen: 1 hour 4 min ago
How much this light cost?
beam0
beam0's picture
Cool.
So it looks like you can turn on the heads individually which is great, are there different levels for each LED? H-M-L or ramping?
Also is there a shortcut to turn on all 4 at once? Or does it start that way?
I’m thinking this could be a good candidate for modding to a flood/throw hybird by putting triples or quads (w/floody TIR optics) in two of the heads, and HI’s or dedomed LED’s in the other two. Might be hard to make the spacers though, I wanted to do this on a BST but proper spacers were an issue.
DB Custom
DB Custom's picture
4 triples? Interesting, or two triples and two HI’s….
Firelight2
I wonder if this light would be more useful if each head was mounted on a ball mount so they could all tilt the same direction. That way you could get all the light one target off to the side. Or you could spread the beams slightly for a more area effect.
stephenk
stephenk's picture
Last seen: 3 days 19 hours ago
Very interesting light, with lots of potential for light painting art due to the moveable heads. Thanks for the review!
Pete7874
Pete7874's picture
Last seen: 4 hours 5 min ago
Max beam distance?
beam0
beam0's picture
Two triples and two HI’s.
So we can turn on only the two triples for flood.
Or turn on only the two HI’s for throw.
Or turn on all 4 heads for max output/flood/throw.
I was hoping you like the idea… because I know you can do it. Wink
From what I’m seeing we can turn on 1/2/3/4 heads separate or combined in any combination, so the driver is right for it. I have (recently) been looking for a driver that can do this for the BST, the NAGE clone was real close, but it only does 1/2/4. (I needed 2/2/4)
But making proper triple spacers to fit the heads wasn’t lookin good for me. After the past month trying to find a light or driver that worked like this I was kind of shocked when I saw this.
How do you scroll through the 5 levels? Taps or long press? Does it scroll through 5 levels and OFF for each switch pad?
Also is there a shortcut to all 4 heads ON? Or would you need to circle around and press each button for that?
I can’t hear the audio on your video, and can’t really tell what you’re doing with the switch…(but I know it was just to show the display)
DB Custom
DB Custom's picture
The center pad is on/off, long press for off once on. It also controls blinkies through a double click, single clicks once in the blinkies menu scrolls through the blinkies, double click goes back to normal operation.
When on, the 4 arrow buttons turn on/off the 4 heads, the arrow pointing back to you is the top head, the arrow pointing away from you is the bottom head, left and right are left and right. If you’ve turned off any heads and turn the light off, when you turn it back on all 4 heads are back on by default.
So you can scroll through 5 modes with only one head, or any combination of the 4 heads, but the menu controls all heads simultaneously in any combination. So you can’t apply a different level to different heads in other words.
So click the center switch to turn the light on (if not locked out) It will come on in last mode memory. Scroll to the level desired, select which heads you want working while on. Turn it off in level 3 of 5 with only one head working and when you turn it back on it will be on level 3 of 5 with all 4 working.
When they sent me this, I was told it was the only one. More samples were being made for testing, but I haven’t heard what the status is on this.
DB Custom
DB Custom's picture
Tell you what, spread the 4 heads at about 1/3 of their range to divide the spots and hit Strobe, MAN! Twist it in slow circles while it’s Strobing like this, pretty wicked stuff! lol
DB Custom
DB Custom's picture
The individual reflectors appear to be approx 21mm in diameter and 21mm deep. The spot provided by these is pretty nice with low spill and no artifacts. There is a SS bezel on top of each glass lens, no AR coatings on the glass, so in theory it would be possible to open each head and gain access to the emitter’s as with the Terminator. I haven’t disassembled anything to date, only put the cells in it. It has built in charging and seems to function well so I’ve used this a couple of times and used an external charger a couple of times. The display window at one point showed 4.15V, each cell was at 4.16V on my MiBoxer C4-12. So the display readout seems pretty accurate.
I intend to see if the tail cap is glued on, perhaps do a spring bypass on the negative springs and see how it acts…
