Closed NEW Soraa 95CRI 3000k PAR38 GU24 Recessed/Kitchen/indoor/outdoor lights (I just want them gone)
39 posts / 0 new
Ronin42
Ronin42's picture
Last seen: 3 weeks 9 hours ago
Closed
OK here is the deal
This is meant for folks who can use them.
FYI these are NOT MR16 bulbs these are big long bulbs. Great for use in kitchens (but you need to plan or confirm they will fit) could certainly work in Baths also (same caveat), lets make sure what I am sending is what your expecting (remember the #2 goal here is to get them used, not just to sit at a new address) thank you again
Sending them to folks who “plan” on flipping them (because these are very expensive lights) is NOT the reason I am making the offer.
I wanted to give something back to BLF at large. I have been trying to sell them and I can tell you that the world does not get “PAR 38” bulbs especially ones with messy water damaged boxes. So if you don’t know what these are, but figure you can always throw them out (your missing the point) and you may want to save your money (and my time) shipping to just throw them out later. (not trying to sound harsh, but seeking to be clear)
Brand new
SP38G-18-36D-930-03
AND/OR
SP38G-18-25D-930-03
aka 3000k 95CRI lights
Expect factory box to be water damaged/(will remove from box and pack loose with padding and lid from box) each But has good intact labels so don’t worry about confusion. They have been 100% tested and are fine (as the bulbs are water proof) but no good for retail sale
Trying to juggle to fill every ones order. It looks like shipping is $20 per LG Flat rate USPS box (I just want them gone)
(open to shipping any odd quantities) The master shipping cases dissolved first, so I’m planning on shipping “smaller amounts” USPS medium or large flat rate boxes, still working out qty per. And/or UPS for larger qty (would like to serve as many folks as possible but #1 objective is to just make them disappear.
Just so you know they way I tested them is I bought Cheap GU24 to E26/7 adapters for a $1-$2 each so (adapters not included) then these can be used in “normal bulb sockets” That is how I tested them. But allow for a 5 inch long bulbs plus adapter if used and a 5 inch wide bulb so some fixtures will be too small. For example not good with lamps with shades (true, but LOL).
Bulbs will be weighted and prioritized in order of posted responses (below)/finalized count, acceptable degree spec, address and payment also matter. Will try to stay with first complete order first served. (“cases” no longer available, all orders on an individual basis. actual project size matters).
Please include quantity desired (meaning count your fixtures or project plan for total used) and preferred beam width (and also if beam width is a deal breaker) in PM, will respond to each member separately.
Will close or remove posting when out of stock. So as long as you see the ad I am still making orders.
If you haven’t/cant wire your project for GU24 you can still use these but they need an adapter to fit in normal sockets (adapter shown below)
(“It’s good that most people can’t remember their previous lives. Otherwise
things would be a lot more complicated than they already are.”
Ajaan Lee Dhammadharo)
Edited by: Ronin42 on 05/29/2018 - 16:45
ImA4Wheelr
Last seen: 1 day 13 hours ago
I'll take a case.  PM incoming.  Thank you.
EDIT:  Given the update to the OP, I have reduced the quantity requested.
Lick
Lick's picture
Last seen: 8 months 2 days ago
I’ll take a case too! Thank you!!
Lightbringer
Lightbringer's picture
Last seen: 6 hours 1 min ago
I’ll take a case if ya still got, tnx!
Wide/flood preferred, but either is fine. Track lighting, over a dozen fixtures over the whole length.
ImA4Wheelr
Given the update to the OP, I have reduced my requested quantity.  Thank you again Ronin42.
AlexGT
AlexGT's picture
Last seen: 4 min 20 sec ago
I would love to have 4 please, (2) 25 degree and (2) 36 degree if possible
Thank you so much! SmileBeer
Edit: PM sent!
RobertB
RobertB's picture
Last seen: 6 hours 46 min ago
Gutting and rebuilding our kitchen. PM sent.
Ronin42
Ronin42's picture
Need more projects where 25 Degree is OK.
Bump
Ronin42
Ronin42's picture
ImA4Wheelr wrote:
I’ll take a case.  PM incoming.  Thank you.
ImA4Wheelr:
Your Nurmero Uno happy recipient.
Sent today
Ronin42
Ronin42's picture
Edit: PM sent!
Alex Sorry to hear the PAR38 will not work for your project, but thanks for checking ahead of time.
DavidEF
DavidEF's picture
Last seen: 7 hours 44 min ago
Oh man! I so wish these were “regular” style GU24 bulbs! I have a ceiling fan that uses GU24 CFL’s and I’ve looked for LED replacement bulbs, but they are, indeed expensive. This is a wonderful gift you’re giving away. I wish my lights could use them.
- The YKK Philosophy
Ronin42
Ronin42's picture
David I know just enough to be dangerous about bulbs. How are these non standard GU24?
Could you be wishing they were PAR 30 instead of PAR 38?
Or “regular” E26, E27 thread in Edison?
Inquiring minds want to know
DavidEF
DavidEF's picture
Yeah, I meant “regular” like Edison style screw-ins but with the GU24 base. What I have now is a light fixture that uses 4x CFL “twister” bulbs that have GU24 base. They are the size of a “regular” light bulb. What you have are what we call “can light” or “track” style bulbs.
My local home improvement store doesn’t carry any LED with GU24 base, only CFL. I looked online for them and I finally found some, but I didn’t have the funds to buy anyway. The bulbs you have (and even PAR30) would be way too big for my light fixture.
ImA4Wheelr
ImA4Wheelr: Your Nurmero Uno happy recipient. Sent today
Awesome!  Thank  you Ronin42 Smile
Ronin42
Ronin42's picture
David no hard sell intended. I wanted to be clear for readers
The GU24 base does indeed fit your fixtures. What I think what we agree on is that the PAR38 is way to large for your fixture or aesthetics.
No worries and thanks
DavidEF
DavidEF's picture
Yes, exactly that. Thanks for offering these to the community. I hope all your excess bulbs find their way into the hands of people who can use them.
Ronin42
Ronin42's picture
Your customer #2
Boxes are in the post. Smile
Lightbringer
Kewl, tnx! I’ll give them a good home. Smile
Lyyyyghtey
Last seen: 10 hours 6 min ago
I can use (5) of them, all the narrow 25° type if possible. Thank you for doing this!
Ronin42
Ronin42's picture
No worries
nqcken
Last seen: 4 days 22 hours ago
i would take five wide angle if possible
ken
RobertB
RobertB's picture
Here are the beam angles for these lights
electricjelly
electricjelly's picture
Last seen: 1 hour 17 min ago
Pm sent
Ronin42
Ronin42's picture
!{width:100%}https://i.imgur.com/BF3NoyM.jpg!
Thanks for the beam charts.
BTW your happy customer #3 shipped today.
ImA4Wheelr
I received my box yesterday.  Nice lights for sure.  Well built, nice tint and cri.  These will definitely light a room beautifully.  Playing with all kind of ideas now how to best use them.  Thank you again Ronin42.  Very generous of you to give these lights away.  Smile
One of the lights is slated for exploration to creat a flashlight.  Began disassembly.  Has an interesting looking LED that I have not identified.  Has a Vf of about 30vdc when operating in the light.  Has a good number of dies.  Reminds me of the MT-G2 in that regard.  The design should make it easy to put on copper and direct wire without traces.  If I do that, I will need secure the leads so that they can not be pulled and damage the emitter.
Lightbringer
Oooooh…
3 words:
          high
          CRI
          lantern.
Lyyyyghtey
Lightbringer wrote:
Oooooh…
3 words:
          high
          CRI
          lantern.
Yes, great idea! It reminds me of a Yuji COB engine but different board. I wonder who makes this LED? Does SORAA get involved at the phosphor level? A suitable boost regulator could drive this off a suitable power tool or lead-acid battery pretty easily.
Edit: although I’d have to be careful which power tool battery. One manufacturer of a 4AH dark-grey-and-orange battery containing 3S2P 20R cells didn’t see it necessary to include battery undervoltage cutoff in their BMS, ruined one that way:(…
To my lantern I’d probably add a second control channel (with buck regulator) that drove a (few) cheap Luxeon-I-knockoff 30,000K emitter(s) for when I’m out in the boonies and want to simulate being in an abandoned mansion lit by wan rays of moonlight spilling through the windows. But maybe that’s just me. (Even though moonlight is not even close to 30,000K!) Of course 30,000K at 90+ CRI would be even better!
Oh, I almost forgot. Of course there’d have to be a 3rd channel with 1900K 90+ CRI LEDs too!!!
Ronin42
Ronin42's picture
Soraa is the MFG. Their claim to fame is a special GaN-on-GaN Thingy
Proprietary LED technology manufactured in California, a technological breakthrough that we further enhance by focusing on every aspect of producing the most natural light possible.
pc_light
pc_light's picture
Last seen: 21 hours 31 min ago
I’m in for 2 that are destined for the basement workshop.
pm sent.
Thanks Ronin42.
Move towards the light.
Ronin42
Ronin42's picture
electricjelly wrote:
Pm sent
Your Happy customer #4
RobertB
RobertB's picture
Got them in today. 3 days was perfect. Thank you!
