List of 18650 rechargeable torches about 4" long?
List of 18650 rechargeable torches about 4” long:
UltraTac S20
OnTheRoad U18
Nitenumen C8
Towild BC03
I have the above four and like them with the U18 my fave of the bunch (OP reflector, great tint, usb cover is perfect, great UI) It is a tad long and a tad thick in the head though and no phone charging.
There also is the:
Folomov C4
Any others? Trying to find the perfect one. Doubt I will. Definitely want OP reflector and a 5000k abouts tint.
Jetbeam EC-R26 is about 4” long as well, but it’s not perfect either.
There is also Manker U11, Olight S2R, Nitecore MH20, EagleTac DX3B Mini Pro.
Lumintop SD Mini. Just a hair over 4”. One of my favorite pocket throwers with a decent hot spot and a bit of spill. I can post a beam shot if you like once it gets dark here.
I like the looks of that light. Reasonably priced as well. Put it on my list of ones to try. Thanks.
Just a warning, the UI is probably its biggest drawback - a rather long press to on, and long press to off.
18650 lights between 3.8” and 4.2”: http://flashlights.parametrek.com/index.html?battery=1x18650&features=integrated%20charger&length=96+107
That UI goes High to low right? I’m definitely in the Low-to High mode change preference group.
That won’t be too bad. I carry my newly acquired EDC05 around and it works like that. Long press to turn on in last mode. Long press for off. Got use to it pretty quick. Thanks for the tip.
Thanks. That Manker U11 NW might just be what I’m looking for travelEDC-wise.
Yes, high to low, with mode memory.
Yes, but it’s not the typical 0.5 seconds long. It’s more like 2 seconds long.
manker u11 is rechargeable and about 4” long or less, but i do NOT recommend it, poor switch design will break
dqg tiny 18650 IV - very small but not rechargeable and another poor switch design
wle
