I reported Sofirn all the suggestiopns a few weeks ago so now it is only up to them what they coming up with.
Hi all!
I got a message today from Sofirn. 21700 chosen. That is confirmed. And the driver size will be bigger to make modding easier. They want dual switch but it is not decided yet. Maybe it will be dual switch or switched tailcap can be bought separately. They told me there will be some changes in UI but I don’t know exactly the changes yet.
:+1: … Thanks for the update.
What about single emitter version will they get 21700 too ?
There is no info about it. I will ask. And also single emitter side switch version.
Dual switch and 21700! Holy cow! Sofirn is on fire!
Yes!
Buying some 21700s now.
What do you thing is appropriate, the Samsung 48G which can do 10A continous? Maybe the 40T which should do 20+A continuous?
The 40T would be the best balance between power and capacity, especially in a triple FET like this.
Kind of like a 21700 30Q.
If you want a regulated driver however, the 48G would be your best bet.
And the 30T would be kind of dangerous with low enough resistance contacts at startup.
You sound undecided.
I thought you just bought some. We’re you just exaggerating? Lol
If not, what did you buy and did you get a decent price?
Since I already have 20700A cells, I’m still undecided whether I should just buy 21700s, or just use it with 20700As. I do not like buying excessive amounts of cells if I already have a bunch of almost new ones.
I didn’t buy it in the end on the Sunway store: https://www.aliexpress.com/store/product/Free-shipping-Original-Sunway-21700-3-7V-4000mAh-40A-discharger-Power-batteries-Li-ion-Rechargeable-Battery/3173029_32855373702.html?spm=2114.12010608.0.0.5d7d69d4sKl14V
These are based on the Samsung 40T 30A rated cells.
Apparently, they are legit and ship to Canada, but I think I’m just going to stick with using my Sanyo NCR20700A cells, and not buy any 21700s, for now anyway.
I would use 20700 for now and wait at least until Sony shows their 21700.
I just tried a Samsung 30T in a Lucky Sun F3X that has 3 XP-L emitters, tail current was 14.1A.
Oh. That is not so bad after all.
14A is a lot of current after all, and other parts of the light are going to offer higher resistance if the springs are bypassed with thick 18AWG wire.
That is why I don’t really want double switch. The clicky will add resistance and maybe melting down under those high currents. I know Dale has plenty lights without problems but I had a triple Nichia VG10 with 15A current and it melted the switch completely.
Cool that they went with the 21700, this will possibly be my first 21700 flashlight, so now I have to find someone who’d ship a 21700 cell to my country
My suggestion for UI: run Andúril!
My plan B suggestion for UI:
- click from off to turn on at minimum
- hold from off to turn on at memory (doesn’t memorize moonlight, turbo or blinkies)
- hold from on to turn off
- click from on to change modes, modes should be Moonlight >low >medium>high (highest possible with no septdown) > turbo (highest possible, stepdown to high or medium)
- double click can be shortcut for something
- blinkies optional
There is the Sunway store link I provided earlier. Apparently, using Turkey Post allows to circumvent easily and legally lithium ion shipping regulations:
https://sunway.aliexpress.com/store/3173029
Also, Banggood ships 18650s everywhere now! I can even order 21700s cells now from Banggood in Canada:
Not just that, but any make/break cycle will go melting off little bits of the contact. That’s a danger for any high-current light with a clicky, but moreso if you’re throwing a 21700 at it going full-tilt.
And with each pit that forms, resistance starts sneaking up higher and higher, a teeny tiny little bit at a time.
Something like (Lexel’s?) FET-switch would be a good way to go.
Not sure if it was mentioned but with this new cell people are going to want to try play around with emitters I imagine. Can you see if they will make a 32mm mcpcb fit without filing? LED4Power has some 32mm 4040 boards coming out and 32mm 5050 options exist too but are hard to find.
They do sell a 30mm triple MCPCB though made specifically for the C8F:
https://www.aliexpress.com/store/product/C8F-DTP-Copper-MCPCB-30MM-Direct-thermal-path-for-triple-LED-diodes/2933049_32847291392.html?spm=2114.12010612.0.0.7a26301ds1gqUv
