I cant pass on the chance to own the most useful and best quality lantern ever made. I have gone from indifferent to excited for its arrival. Good job all involved. I just ordered the batteries for it.
I have not read every page so excuse me if Im being repetitiveâŚ
Was there any discussion of having an external partial/adjustable or rotating reflector/shield that could attach to the outside of the lens?
It would block light at certain angles or say 90-180 degrees to provide a dark area or âno lightâ zone. It would also reflect that same blocked light back to the rest of the unblocked area actually increasing output or allowing a lower setting to the desired areas. This would allow light to be directed to areas or parts of the 360 light pie that need it and block or black out direct light in eyes or windows on bedrooms of motorhomes or tents where people are sleeping that donât need it.
I have been in camps where there was discussion as to whether to turn the lantern up or down or off altogether for certain people who either didnât want so much light or just wanted to block it from shining directly on them. We have actually tried to hang things to block areas from being lighted in the past with standard 360 lighting. We wanted the table behind the lantern well lit and the people on the front side could have seen fine and not been blinded by the direct beam with just the reflected light bouncing off the trailer and table.
This dual purpose shield/reflector could be attached so as to rotate or possibly be raised or removed completely. It would serve to block the back side light and increase front side lighting (flat white) and could be made inexpensively.
So my attempts at sharing the list via google docs has been a learning experience. The links above required folks to request access from me to read the document, which is a PITA for the folks that want to read it as well as me. I believe this link works and folks wonât have to ask permission. You should be able to copy the text and paste it where ever you like, or search it for your (or anyone elses) name.
Let me know if you have success or not, thanks!
PS, google docs takes 5 minutes to update a âpushlishedâ document, which this interest list is.
I have not read every page either, but I donât pretty certain this in not a feature of the light as currently designed. I think it would be an interesting enhancement though . . .
thanks for the feedback! I looked right after I added you, and it was not there yet, thatâs why I edited my post above. Glad it is there now, 5 minutes is not too long to wait.
In order to upgrade to the premium version of the reflector, put tape on the sharp tin edges so you donât cut yourself and add a rubber band for extra holding power.
This premium upgrade sounds like a winner if the removable adjustable rotation angular selective luminance reflector/decreaser unit does not make the final cut.
I will make one from my favorite of the canned species of beers I often drink to proudly showcase my metalworking taping prowess.
Good ideal though. maybe can be something built as an accessory kit for the lantern once we get the lantern itself in production, ( kit could include a reflector, storage case or sleeve, wall-charger or solar charger & cable, etc.
Edit: going to do some photos of the beam pattern tonight on the V2 versus V1 & other lanterns.
I would be in for the kit and assume others would as well.
The only reason I bring it up now is that the pivoting or removable mounting design I had in mind might need to be tooled into the lantern from the get go. It could snap on the same way a belt clip does and slide around the unit while gripping the notch and suspending it away from the outer lens a bit to prevent rub marks. If it was plastic, it would be inexpensive, durable and would not scratch the ano. It could have a top and bottom groove to add stability.
Since the lantern is based from the Q8 body, it currently has a side 1/4-20 threaded tripod mount, and the reflector/shade could even mount to that point, ( its probably easy to leave that side mount on the production lantern model too for that.
