petemer
(petemer)
May 14, 2018, 8:10pm
1059
ThorFire TK18 XP-L2 1200LM Stepless & Mode-Dimming Memory Function Tactical LED UI Flashlight
Coupon code with sizeable discount is available.
» Request via PM here«
Cree XP-L2 LED NW (5350-5500K)
dual switch (rubber taillick + side e-switch)
LED charge indicator in side switch
18650 or or 2x CR123A battery powered
max 1200 lm
3lm low
2 UI modes: 5 predefined modes (4 constant + hidden bike strobe) or continuous ramping 3-1200lm
momentary on function
» Jump to First post quick links/deals list «
petemer
(petemer)
May 14, 2018, 8:22pm
1060
SET | ThorFire TK18 XP-L2 1200LM Stepless Dimming Tactical UI Flashlight with 18650/USB Cable/Charger
max 1200 lm
3lm low
3000mAh battery, charger and cable included
petemer
(petemer)
May 18, 2018, 1:38pm
1061
petemer
(petemer)
May 16, 2018, 5:20pm
1062
petemer
(petemer)
May 16, 2018, 5:39pm
1063
petemer
(petemer)
May 17, 2018, 6:58pm
1064
Xiaomi Mi Note 3 5.5 Inch Facial-Recognition 6GB RAM 64GB ROM Snapdragon 660 Octa Core 4G Smartphone
Use coupon code 5BGNOTE3 for massive $63.00 discount - price drops to only $286.99
6GB LPDDR4 1866MHz RAM
64GB UFS ROM
5,5” Full HD IPS screen
3500mAh battery
under-glass fingerprint sensor
3D curved glass body
metal frame
USB-C with QuickCharge 3.0
dual 12 Mpix rear camera with optical zoom and 4 axis optical image stabilisation
16 Mpix front camera
NFC
petemer
(petemer)
May 18, 2018, 12:29pm
1065
petemer
(petemer)
May 18, 2018, 12:38pm
1066
petemer
(petemer)
May 18, 2018, 12:47pm
1067
petemer
(petemer)
May 18, 2018, 1:34pm
1068
LightFe MK62 XP-G2 S3 280LM 3Modes 180° Adjustable Head USB Rechargeable Mini Keychain Light EDC Flashlight
Coupon code with additional discount is available.
Unique 180 degree rotary head
Cree XP-G2 S3
3 colors: black, red, golden/yellow
3 mode groups:
high/medium/low
strobe/SOS/beacon
red -green alternative flashing (additional LEDs on both sides of button )
looks moddable (easy to open: side screws + head screws)
petemer
(petemer)
May 18, 2018, 1:43pm
1069
petemer
(petemer)
May 18, 2018, 1:55pm
1070
ZozzV6
(ZozzV6)
May 18, 2018, 5:04pm
1071
Hi petemer! Can you ask some coupon code for Eagle Eye X2R 3C led version?
Thank you!
beam0
(beam0)
May 20, 2018, 10:18pm
1072
I like these new Sunwayman lights,
looks like a good UI:
Activation of the light:
A quick depress of the switch at the top to turn the light on; hold the switch the light will cycle through Low-Mid-High-Turbo. Last mode memorized.
Hidden Modes:
A quick double-click will activate Strobe and another quick double-click under Strobe will enter SOS.
(I assume it’s single click to turn it off)
Interesting they are using XM-L2 when most new lights are using XP-L / XP-L2.
The smaller one’s about the same size an a Nitecore MH20GT
Pretty cool “wave” knurling.
petemer
(petemer)
May 21, 2018, 11:10am
1073
CRELANT V5CS XM-L2 18650 960LM Camping LED Flashlight
Use coupon code d5e70b for additional discount to get final price of $23.99
3C and 5C tints in stock (7C is under restocking)
dual switch design: side e-click + tactical tail switch
High, Low, Strobe, SOS, Stepless dimming (5–100) with memory function
petemer
(petemer)
May 21, 2018, 11:15am
1074
petemer
(petemer)
May 21, 2018, 12:20pm
1075
petemer
(petemer)
May 21, 2018, 12:36pm
1076
JoinRun S4 4Slots EU Plug LCD Display Automatic Rapid Intelligent Li-ion/NI-MH/NI-CD Battery Charger
Use coupon code 1b30d2 to get additional discount and $22.99 final price($39.90 -> $28.79 )
It’s shipped with US cord and adequate adapter for your country but it’s powered by standard figure-8 cable so you can use any matching cable lying around. Can also be powered by 12V DC power source with barrel plug(car adapter is not included).
compatible with all popular chemistries (Li-ion 4.2V and 4.35V, LiFePO4, Ni-Mh/Ni-Cd)
big backlit LCD even shows charging phase (CC, dV, CV)
internal resistance an capacity measuring (apparently one slot only)
800mA/350mA (Li-ion) and 600mA/300mA(Ni-Mh) current per slot
Hey ZozzV6 What you planning to do with Eagle Eye X2R ?
Im just curious
