ALIVE: Haikelite MT07S only US$46.72
186 posts / 0 new
DENGOH
DENGOH's picture
Last seen: 3 weeks 2 days ago
Anyway, if they are indeed having difference of 350m measured by forumer, I think it is quite funny to know Astrolux and Haikelite were using offset numbers quite close to each other to boast their flashlight throw distance.
1587-1200 = 387m. I wonder is it possible they engage the same test house to perform the test and cause this offset from reality.
cool i'll see you when you get there
Satan@103TFS
Last seen: 1 hour 54 min ago
Interested.
M4D M4X
M4D M4X's picture
Last seen: 20 min 29 sec ago
10 more needed
find all available items in this list
i launched my new blog - all deals for members without MAP B$ Wink
find a short description about my idea here
if you want to buy a flashlight or battery for a better price: just send a mail - i will try to save you money!
JakeDjanitor
Last seen: 5 days 15 hours ago
This seems like a better deal than the sc26 group buy that I am in. I am about ready to back out if that group buy. It’s going terribly.
hIKARInoob
hIKARInoob's picture
Last seen: 4 min 47 sec ago
I can highly recommend the MT07S (70.2). Great machining and finish; the light feels really good in the hand. And the output is just amazing. It’s just a joy to use, and the price doesn’t get better than this.
JakeDjanitor
How does it compare to the xhp 35 model? I have a q8 and an l6 for the medium distance stuff.
hIKARInoob
I only have the L6, and the beam is pretty comparable (70.2 version). Output of the MT07S 70.2 is about 20% higher than the stock L6. The output of the L6 does reduce with depleting cells which is not the case with the Haikelite.
There is just very little info regarding the 35 version. I think the 35 is an interesting light. It’s not a dedicated thrower like the TN42 or the MF02 with a huge reflector. The MT07S is much more compact and although not too comfortable, it actually is pocketable. I call it a sub thrower.
So for its size you get quite some throw with ~200 kcd intensity. So the 35 is less bright compared to the 70, but you definitely have a tighter more intense hotspot, also relative to the L6 and Q8.
_amass
_amass's picture
Last seen: 1 month 1 week ago
Should I go with the 70 or 35? And why?
Agro
Last seen: 4 hours 5 min ago
How does it compare against q8?
BlueSwordM
BlueSwordM's picture
Last seen: 3 min 36 sec ago
Pros: More throw for both versions, especially the HI version.
Stable brightness as the cells drain in the light
Possibility to install a Lexel buck driver to get the best UI ever.
Better tint than the Q8 with the MT07S HI version, which uses an 80CRI 4800k emitter from my knowledge.
That added weight means it almost does not thermal throttle, even at max, per u/Zak or Zak Wilson’s review.
Cons: Worse UI out of the box. For the XHP 70.2, worse tint than the BLF Q8.
My very own high current Beryllium Copper springs: http://budgetlightforum.com/node/64047
Agro
I see that even the 70.2 variant offers nice throw, 75-96 kcd depending who measured it. About twice that of Q8.
I spent too much on lights recently….but I’m in.
Did anybody do a resistor mod?
BlueSwordM
Resistor mod is possible, but I would not do it personally.
That is because I’m going with Lexel’s buck driver with NarsilM for this light.
Agro
Really, I think it would be best with 2s battery mod and TA.
But I’m not about to do it yet.
GT driver would be a major upgrade, but a major cost as well….so I’ll pass on it.
BlueSwordM
Or just keep the stock driver. The UI is quite nice, and using a 4S battery setup allows for constant 4500 lumens.
And besides, the Lexel buck driver is only 6$ more than the TA driver, and allows for constant brightness regulation.
For this type of light, I prefer constant brightness since I like that a lot.
CoolJB
Last seen: 3 weeks 1 day ago
Been watching this deal since it was posted. Finally broke down and registered for it. For $46 I figure what the heck. Plus it will be my first HaikeLite.
Lux-Perpetua
Lux-Perpetua's picture
Last seen: 6 hours 58 min ago
Martin, do I need to fill out the form or is it sufficient to post my interest here?
M4D M4X
M4D M4X's picture
you are No 89 ( had to remove 10 double entries )
Lexel
Lexel's picture
Last seen: 12 min 38 sec ago
Interested in 10 MT07S XHP70 NW
if they do not have P2 bins they can sell me one without LED and driver dont need them anyway
send the lights each in its own parcel
M4D M4X
M4D M4X's picture
 @Lexel
hast PN
CNCman
CNCman's picture
Last seen: 1 hour 53 min ago
I’m in for the “ HaikeLite MT07S HI Upgrade Version 3000Lumens CW/NW Long Range LED Flashlight 1200M – Black Cool white light “ version with the SMO reflector.
Which is the better thrower ? NW 4800K or CW 6500K ???
Thank You M4D M4X Beer
CNC & Manual Machinist. Think outside the box too long , cannot find your way back in.
Good Intentions are no guarantee for Good Results.
BlueSwordM
The better thrower will always be the one with a lower color temperature.
Lower color temperature=lower wavelength=higher range=better thrower
Also, the 4800k version of both the XHP 70.2 and XHP35HI are 80CRI, versus the 6500k 70CRI, so much better again there.
CNCman
CNCman's picture
Thanks BlueSwordM Thumbs Up
So if I understand what you are saying, the NW 4800K HaikeLite MT07S HI Upgrade Version 3000Lumens , is the longest thrower of the group. And will give the best color distinction on objects as well at 80CRI. I am still learning the basics. I will Google more…..
SKV89
Last seen: 10 hours 15 min ago
hIKARInoob wrote:
I only have the L6, and the beam is pretty comparable (70.2 version). Output of the MT07S 70.2 is about 20% higher than the stock L6. The output of the L6 does reduce with depleting cells which is not the case with the Haikelite. There is just very little info regarding the 35 version. I think the 35 is an interesting light. It’s not a dedicated thrower like the TN42 or the MF02 with a huge reflector. The MT07S is much more compact and although not too comfortable, it actually is pocketable. I call it a sub thrower. So for its size you get quite some throw with ~200 kcd intensity. So the 35 is less bright compared to the 70, but you definitely have a tighter more intense hotspot, also relative to the L6 and Q8.
Is the 35 HI or 70.2 version the one measured at 200kcd?
hIKARInoob
That’s the 35 from one source. The 70 does about ~70 kcd or so.
M4D M4X
M4D M4X's picture
groupbuy is ALIVE!  Beer
i sent the codes to all adresses on the list
if you did not get a mail please try to reenter and check your spam folder
Nicolicous
Nicolicous's picture
Last seen: 2 hours 3 min ago
unsure which one i should get XHP 70.2 or XHP35HI Sad
one is a thrower and the other is flood Davie
Nico -.-
Agro
Ordered black NW 70.2.
Thanks M4D M4X.
Itsme
Last seen: 8 hours 7 min ago
Grabbed a White NW XHP35HI
Thanks for the great code!
M4D M4X
M4D M4X's picture
you are welcome !
thanks for your support! Smile
Lux-Perpetua
Servus Martin,
I also fell in love with the MT07S. Form has just been filled out. Wink
Thank you! Thumbs Up
P.S. Oh shoot…I came too late…black is sold out. I hope stock will be replenished soon.
