Activation of the light:
A quick depress of the switch at the top to turn the light on; hold the switch the light will cycle through Low-Mid-High-Turbo. Last mode memorized.
Hidden Modes:
A quick double-click will activate Strobe and another quick double-click under Strobe will enter SOS.
(I assume it’s single click to turn it off)
Interesting they are using XM-L2 when most new lights are using XP-L / XP-L2.
The smaller one’s about the same size an a Nitecore MH20GT
Pretty cool “wave” knurling.
Use coupon code 1b30d2 to get additional discount and $22.99 final price($39.90 -> $28.79)
It’s shipped with US cord and adequate adapter for your country but it’s powered by standard figure-8 cable so you can use any matching cable lying around. Can also be powered by 12V DC power source with barrel plug(car adapter is not included).
compatible with all popular chemistries (Li-ion 4.2V and 4.35V, LiFePO4, Ni-Mh/Ni-Cd)
big backlit LCD even shows charging phase (CC, dV, CV)
internal resistance an capacity measuring (apparently one slot only)
800mA/350mA (Li-ion) and 600mA/300mA(Ni-Mh) current per slot
There is always some people who asking for a flashlight around the house and that is good for beginners and easy to use. So I always keep 2-3 new pieces for them.
Totally. This is great flashlight for non-flashoholics with decent output, good tint and at ~670lm you don’t have issues with heat.
Built in micro USB charging is great because user doesn’t have to handle the cell at all - just use it like common cellphone. So with good quality cell it’s imho as safe for a newbie as possible for li-ion based light.
There’s only one thing to be aware of - to charge the cell inside the flashlight you have to turn the switch on as it’ mechanical switch which breaks the circuit otherwise. If you put 3500mAh cell inside, it lasts so long with sporadic use that some users tend to forget the fact and then call to sulk their’s great flashlight doesn’t turn on anymore - just flickers and doesn’t charge
But this design also have the advantage of zero standby current draw when not used so no issues with drained cells after few weeks or even months.
Use coupon code 282233 to drop $25.99 price to only $17.99 (–8$ / –30%) Best price to date!
This is high quality precision screwdriver set with well designed(they even win reddot award) and compact case. See reviews @Banggood product page - there are also user provided real photos that better show the high end craftmanship.
