Prices are not worked out yet, ( for the group buy and the retail after) which will be worked out by Thorfire.
Please, add me for one more, total of 2. I am #255 in the list.
GreenLights: DBSAR:the BLF Q8 with the best diffuser i found (and have tested that fits perfectly)
Would you please share what this diffuser is and/or where to get one? Thanks.
I sort of tried different things to get the right diffusion level that seems to work the best with out decreasing lumens form the LEDs. ( i am using a plastic frosted cup, with an additional frosted sleve atm to get the best beam pattern. I can take photos of it later to show.
I’m pretty sure he was talking about that diffuser “cone” you used to test against the prototypes, not the piece you used on the actual prototype.
DBSAR: GreenLights: DBSAR:the BLF Q8 with the best diffuser i found (and have tested that fits perfectly)
ah yes, the one i found for the Q8. Its the diffuser head from this flame light: Amazon.ca
It has a shoulder and fits on the Q8 bezel perfectly & locks in place. I am using the flame unit its self for another electric simulated campfire.
Yes, interested
This is great, thanks!
I really need to get in on this, please add me to the list for 1 pc.
Great work DBSAR, thanks for all the time and effort you’re putting in on this!
Don’t know why I’ve ignored this for so long but I really like the way it’s evolving.
i added the bottom tripod mount to the lantern as talked about earlier in the topic, ( in this case i added a 1/8” aluminum plate inside the bottom cap, then threaded it with the 1/4-20” standard tripod hole. then sealed in the inside to make it waterproof.
Nice! I had been thinking about looking into doing something like this on my Q8, can this mod be done to a regular stock Q8?
Jumping in for a 2nd one please.
DBSAR:i added the bottom tripod mount to the lantern as talked about earlier in the topic, ( in this case i added a 1/8” aluminum plate inside the bottom cap, then threaded it with the 1/4-20” standard tripod hole. then sealed in the inside to make it waterproof.
Yeah, it was a stock Q8 before he modded it.
The standard Q8 tail cap metal is to thin, i had to add a 1/8” thick aluminum plate inside the tail cap using JB-weld to make it thick enough to thread it so it can hold onto the tripod mounts.
Hi CJ, you currently are on the list 3 times,
174 CJ Avlis
263 CJ Avlis
447 CJ Avlis
Should I add you for a fourth?
What I am planning on doing in the interest list going forward is providing it to DBSAR sorted alphabetically by user name, so you can easily look in the first post and see where you stand. This would be updated every so often, maybe twice a month, or more often if folks want. It is pretty easy to do for me, the magic of a spreadsheet. I’ll add a link to it below, but it seemed like for some reason several folks are having problems seeing the numerically ordered interest list, so don’t be surprised if you have problems with this one as well. Just ask for permission to see it if you need to.
I’ll continue to keep up the order of interest document which I have been linking to for the past week or so as soon as people request to be added, but will update the listing in the spreadsheet sorted by peoples name just periodically, like every other week or so (as mentioned above). Hopefully this helps folks know where they stand in terms of how many lanterns they have showed interest in to date.
That would be awesome idea
The list I created above is functional, but I am reworking it a bit to be easier to read. Hope to be done in a couple days or so.
So is the cooperation with Thorfire working out sofar?
Anyone know if this lantern use unprotected or protected ? I want to start shopping for some protected 18650 if it does…
