Texas_Ace BLF Calibrated Lumen tube / Sphere No math skills needed - Several spheres still available
That hit me later, if they are ANSI then they will be at 30 seconds although the large discrepancy between 2 lights rated the same tells me they are not exactly rated precisely in the first place.
That said I am still not attached to the calibration I have now but I also want to see a lot more data before a change is decided.
We should really be testing stock fenix light… fenix lumen number are legit…
I don’t know much about it. But, maybe the drivers have different properties that make them start at different levels, even though they ‘should’ land at the same level at 30 seconds? Or maybe Charles was using different cells for those lights, and that is what made the discrepancy at start?
All are possible, this is why I game up on using lights to calibrate my sphere, there was just too many variables. At least with bare LED’s I vastly reduced the variable.
That said, these are the only spheres calibrated that this way that I know of, so I have no idea how they compare.
I was also thinking and I was using China LED’s for most of the time I was calibrating my sphere. I did not start using Mouser until after that IIRC.
I just message with vinh. Skylumen… nitecore lumen are after 30 seconds…
Got mine today, had not tracked so was surprised.
Have to say lately I have been bored with flashlights and real life has taken over my time. But after opening the box and setting it up I was grabbing all kinds of flashlights that I have not handled in 6 months to try them and think the readings are pretty good.
First one tried was trusty old Sofirn PF04, EDC it every day and it came up as 236 lumens, they rate it at 240 and Sofirn is usually fairly honest on their readings or a tad under rated so that was a good first try.
Next up was a C8 by SeresRoad which is pretty much a Thorfire C8 XML2 that came in at 1090 lumen pretty much what was expected.
Also tried a Sofirn SP32a, showed 1350 with Panasonic utility battery, tried a Samsung 30Q and it went over 2100, the meter auto-ranged up at that point and read 210.
Did not keep it on for long as that light gets hot quick in turbo and didn’t want to risk frying the emitter. That is why I run the less powerful battery in it for safe daily use.
So, so far I like this rig.
Told the Wife it is a “Precision Measuring Device” and not a new toy :slight_smile:
Anyway Hat’s off to Texas_Ace and his “Team” for delivering the goods ahead of time and on Budget.
I feel blessed to have gotten one at the price paid and am happy for not being pessimistic.
THANKS!!!
Later
Keith
I got mine just now.
I’m also surprised by the high readings compared to the JoshK sphere.
I have a Convoy S2+ with QLITE 3A driver and xml2 CW:
JoshK 700
TA tube 1350
On the Road M3 CW: .69
JoshK 862
TA tube 1240 (4v)
Convoy C8 xml2 CW: .65
JoshK 845
TA tube 1310
DQG Tiny 7x 2500lm:
High- .65
JoshK 855
TA tube 1310
Turbo- .64
JoshK 2120
TA tube 3300
These are just quick tests with some batteries at 4v or so. I won’t be able to do more accurate measurements with fully charged cells until tomorrow.
I think the general consensus is that it is indeed reading high.
I tried covering the reflective tape on the spacer ring with black cloth, all I had at the moment, and readings seemed to drop back down to a little above the JoshK sphere. Maybe painting the silver side with flat black and flipping the discs will get the readings in line. (Maybe, requires more thought)
I was a bit skeptical of the JoshK sphere because after measuring lots of lights with it, the readings always seemed a little on the low side. Maybe once you take into account losses in reflectors and lenses maybe it IS accurate?
Anyway, all this will have to wait till later for me.
(NOTE, My JoshK sphere numbers are from a past session. I was comparing that to today’s measurements in the TA tube.
So not a direct comparison. I’ll get both spheres set up tomorrow so I can do back to back tests)
Keep the TA specs number coming… i will put out my numbers on tuesday.
Mine also came today. Its a really cool design and well put together so I’m excited to get it dialed in. I also have a JoskK sphere for comparison, so I ran some quick numbers as well
Light/host Spec Sphere TA Tube Diff
HDS 170 170 168 234 71%
HDS 200 200 203 327 62%
ReyLight Lan N/A 234 327 62%
Swm V10r 219c N/A 315 474 66%
Haiku 219c N/A 390 609 64%
Zebra SC5c mk2 475 427 648 66%
Hanko 219b N/A 615 890 69%
Zebra SC62w 930 891 1362 65%
Zebra SC63w 1150 1086 1748 62%
Zebra SC600w mk2 HI 1126 1120 1738 64%
So a few important points:
  • Like Jason I didn’t bother to test cell voltages because we’re comparing measuring devices here, looking for relative numbers, so it really shouldn’t matter just to try and find a trend. But maybe it will when trying to compare to other users’ numbers so I may need to re-do this when I have more time.
  • The HDS lights are the most interesting to me, because according to Henry at HDS each and every single light is custom calibrated on his sphere to give the promised output. He tweaks the levels in the firmware so that the lumens are exactly as promised, so they should make pretty good “reference” lights for these sorts of tests. Unfortunately (for this application) I’ve modded most of mine which invalidates that work, but these two are still stock.
  • I’ve included “spec” numbers for factory, unmodified lights. They’re just there for reference and not included in the math. Lights marked with N/A are modded in some way so factory numbers, if they ever existed, would be useless.
  • I’m concerned that my differences don’t show a more precise trend. A range of over 9% difference, between the lowest and highest variations, seems like a lot to me. I suspect my “technique” is to blame there which makes all my numbers questionable. I’m still trying to figure out the best way to use this thing.
  • I didn’t include any “high-powered” lights for this test because the JoshK sphere can’t handle them, so I’d have nothing to compare to. If the tube’s response isn’t linear then it may not be off as much at the higher end. I have no way to test that. I did order those numbers above in lowest -> highest order in the hopes of seeing some sort of trend in the differences, but I don’t.
  • More data is definitely needed but I think its safe to conclude that the tubes are reading high, its just a matter of determining how much high. Mine seems to be up by ~35%. I’ve not yet tried to bring it down in any way and look forward to what some of the rest of you come up with.
My JoshK sphere numbers where from a past session. I was comparing that to today’s measurements in the TA tube.
So not a direct comparison. I’ll get both spheres set up tomorrow so I can do back to back tests.
I’m really impressed with how the depth of the flashlight through the opening as well as the angle of the flashlight in the opening doesn’t vary wildly.
You basically just want to aim your light straight down and then move the flashlight up and down a little bit to get the highest results. It’s working really well. :smiley:
Maybe we can watch matt video and use correction factor method of calibration.
Hey charles, try this method.
Turn your nitecore tip for 30 seconds on the lumen tube… then you will get the lux number…
( 240/lux ) = number A.
Number A is your main number…
Put any lights… lux * number A = lumen
I don’t have a horse in this race, but what ever is done to adjust measurement should be similar or consistent with TA’s tube and/or with replicable readings among each of the 30 tubes out there. I am not suggesting one not have fun playing with their own tube, but it seems an important part of having 30+ tubes out there would be that they have similar measurements and a kind of “standard” between them.
It would be nice if everyone had like a “calibration” light or set of lights that would be used as a standard starting point and assuming every similar light was putting out similar lumens (maybe thats impossible…). Maybe there is like one “right on the nose” light everyone might have (BLF Q8?). Everyone blast your “calibration” light in there, calibrate it to an agreed upon or “defined” lumen output, and see if that lets others measure other lights with any consistency.
Could like everyone use some kind of AC lamp with a set rated lumen output, some LED light bulb or something as a cheap and easy to get standard? Everyone buy the same exact LED bulb and go from there?
I suspect my idea is maybe too simple for the sophisticated optics behind tubes and lumens.
I suspect TA will have a better and simpler way to address the calibrations if necessary.
I just like to learn stuff…
Obviously we can figure out a correction factor to use, but I would like to keep the design premise of having a direct lumens reading with no math involved.
Before any modding, the important thing is for the owners to not permanently alter the calibration that TA put on the tubes. So I was trying to figure out a way to reduce all output by a certain percentage.
Maybe making the centering discs do double duty is an option. Keep the reflective tape on one side, but change the silver paint to a less reflective color on the other side.
Instead of repainting, maybe cover the painted side in an adhesive backed felt in a specific color such as black or brown. Felt might be more consistent than paint. The problem with altering the entrance of the tube is that different beam shapes may be affected to differing degrees.
If we need a 50 or 60 percent reduction in output across the board, then we might need to look at the sensor end of the tube. Maybe a thin sheet of tissue paper over the sensor and then stick it in the hole would get the job done. This way you could still have TA’s calibration and then have your own calibration which might be closer to accurate.
So a theory - TA buys a stack of tissue paper, like waxed for instance, tests it out, gets a proper reduction across the board for all light types, then mails out a few sheets to all owners. Maybe we send a few bucks to cover envelopes, stamps and the extra effort. Then everyone’s lights would still be calibrated to each other. Plus we could simply remove the single sheet of tissue paper over the sensor and be right back to stock.
Just a thought.
Also seeing numbers higher than expected. Measurements taken 30sec after turn-on:
Fenix PD35 (freshly charged Samsung INR18650-25R)
spec high = 1,000
TA Tube = 1,600
Acebeam X80 (freshly charged Acebeam 18650s that came with light)
spec medium level = 2,500
TA Tube =2,850
Zebralight SC600w Mk III (freshly charged Samsung INR18650-25R)
spec high (H1) = 1,126
TA Tube = 1,725
Nitecore TIP 2017 (non CRI version) fully charged built-in battery
spec high = 150
TA Tube = 202
spec turbo = 360
TA Tube = 448
J5 Tactical V1-Pro (Olight 14500 battery)
(note, many have suspected they fudge their numbers)
spec for high = 300
TA Tube = 210
Olight S1 Baton (fully charged Olight 14500 battery)
spec high = 500
TA Tube = 730
Olight S1A Baton (fully charged Olight RCR123A)
spec high = 600
TA Tube = 797
Nitecore TINI (fully charged built-in battery)
spec high = 145 , TA Tube = 217
spec turbo = 380 , TA Tube = 545
Olight I3e silver (Panasonic Eneloop Pro AAA)
spec single mode = 120
TA Tube = 173
Olight I3e copper (Panasonic Eneloop Pro AAA)
TA Tube = 167
Olight I3e blue (Panasonic Eneloop Pro AAA)
spec single mode = 90
TA Tube = 128
Olight ION (fully charged built-in battery)
spec high = 320
TA Tube = 447
Adventure Sports Flashlights custom Maglite (2X KeepPower 26650)
spec high = 5,000
TA Tube = 6,550
Rofis ER3A (Panasonic Eneloop Pro AAA)
TA Tube = 145
MecArmy X4S (supplied 10180)
spec high = 130
TA Tube = 158
Klarus P20 (2X Panasonic Eneloop Pro AAA)
spec high = 230
TA Tube = 325
Averaging multiplication correction numbers for all results (excluding the J5 for obvious reasons) gave me a correction factor of .728(
I also noted that the exact position of the light made little difference.
FWIW my SC600w HI Mk3 sample reads within 0.5% of Zebralight’s claim of 1126 lumens at 30 seconds with any good battery (VTC5A, VTC6, 30Q, GA). I’d use that as a good calibration light for that type of beam.
edit: to clarify, this is in a sphere, not in TA’s tube, which I don’t have
Wow, no one seems to have the same lights as me. Here is what I can measure (that are still stock).
Convoy C8 xml2 CW
On the Road M3 CW
OTR U16 CW
OTR U18 CW
DQG Tiny 7× 2500lm CW
Eagle Eye X2R CW
EE X5R CW
Lumintop ODF30 CW
Lumintop Tool AA CW
Lumintop IYP365 CW
Jaxmnve M3 CW
New Boruit 5000lm headlamp
Crelant CH10 Xml2 CW
Zanflare F6 and F6S CW
If anyone else has one of these lights, let me know and we might be able to do some direct comparisons.
Wow your lights are all CW. I always thought you were a WW guy from your username. I have NW versions of some of your lights but can’t really compare them if they are not the same CCT. Might be different flux bin too.
If someone in Europe (shipping stuff back outside EU is too expensive) has the integrating tube and wishes to calibrate it against a sphere, PM me. Sending me two of your own lights with preferably different CCT and CRI and beam profiles would be much better than trying to calibrate against a different sample of the same model.
Maukka, Could you explain why my SC600w HI Mk3 measure 1680 lm@30 seconds in TA’s tube (Zebralight’s spec: H1-1126 lumens), but I got Exactly same M1-61 lm @30 seconds in TA’s tube as Zebralight’s claim??
