Texas_Ace BLF Calibrated Lumen tube / Sphere No math skills needed - Several spheres still available
I have many more lights I want to measure, to fine tune my correction factor.
For those of you who have been into flashlights longer than me, which manufacturers could I trust the most for accurate lumens outputs?
Someone mentioned Fenix. The three I have are PD35, FD40 and FD20.
Or any specific models that have been tested by a reliable source?
I may be on to something. I remember reading somewhere about someone using tissue paper in there lumen tube. Maybe it was TA?
I grabbed an extra waxed paper from donut section of the grocery store this morning. One piece over the sensor dropped it a little, two pieces were closer and three pieces seem just right.
Now the tube is reading pretty much the same as the JoshK sphere or just a tiny bit higher. Assuming that’s what we’re aiming for. Also, the amount of time the light is on before taking the reading does make a large difference and might explain why it’s not exact.
Here’s how I measured my BLF GT. I used a C8 reflector. I then stuck it in the appropriate sized ring. LOL. :stuck_out_tongue:
GT in TA tube:
Stock tube - 3300 lm - obviously too high
3 layers - 2200 lm - pretty realistic
I know it’s not the same without the big reflector and lens, but that doesn’t fit on the 3” tube. No biggie. It’s the only light I have that doesn’t fit.
The reading is about 1/3 higher than what is expected. We’ve seen this value before. The 4” tubes were measuring 1/3 lower, which is related to the fact that a 4” tube
has 1/3 more surface than a 3” tube.
Is there perhaps some kind of mix up?
The final calibration on all the tubes should be the same +/-~5%.
Although I do agree that it is looking like the calibration that I am using is indeed about ~30% too high.
I just need to get some hard data / more data and we can come up with a hard value for a correction factor.
After look at my notes from 2 years ago and applying what I have learned in that time, I am not as surprised that the readings are high, although I am VERY surprised they are so high.
Luckily it is easily correctable once we figure out a good correction factor.
Yes i will send some lights to Finland to get them measured.
… just curious, perhaps others in the know could chime in on this: If these spheres are reading high, does that mean the HaikeLite group buy lights rated around 20,000 lumens after TA’s mods, are are all overrated? This stuff gets confusing :frowning:
thank you
It would seem that way, although when compared to other lights in the same class they compared favorably, so I am not sure what to make of it.
We will need to wait for more data to make nay educated guesses.
agree, it’s just a number, and I couldn’t be happier with my MT03 and TA driver. The driver added some ~ 4000 lumens I think, a wonderful UI, and it’s bright as the sun.
It may just be a number but I still feel horrible that I might of unknowingly mis-represented these lights.
Once some more people get the spheres we can see how things compare with a wider selection of lights.
I am also going to see if I can get some lights measured in an ANSI sphere.
I just need to figure out some very consistent lights for this. Most of the lights I have here are not regulated anymore or not very consistent.
I like to caution the idea of assuming respected manufacturer’s lights are accurate and consistent throughout. I just posted some ceiling bounce results for my AA lights and there are several identical lights from “respectable” companies that show considerable variation in light output. My ceiling bounce measurements have been extremely consistent even when measuring the same light months apart.
Also I prefer we don’t apply our own correction factor and instead apply a standard correction factor among all the lumen tubes. One of the main benefits of so many people owning TA lumen tubes is so we have a standardized basis to compare lumens among members. Even if the lumen tubes are not calibrated to realistic lumens, they are still calibrated consistently among all the units so we need to come up with standardized correction factor.
M43 is very consistent. Output remains constant all the way down to 3.5V (boost driver). I’ve got three identical, and output is very close to each other.
I forgot to post the link at first to see how indentical lights compare AA Flashlight Collection Ceiling Bounce Comparison
I have a question. If the 4” lumen tubes did readings about 30% low when you put them together, Isnt that close to point?
Low as in comparison to the 3” ones.
Yes, as they were setup at the start looks to be pretty close to what they need to be. Although they have now been calibrated up to match the rest so it really doesn’t apply now.
It is also looking like I will be sending some lights to finland for testing on a real sphere so I can get a good calibration.
I am thinking of using an
S2+ with 7135 driver as they are usually pretty stable.
Possibly a BLF348 as I hear they are fairly stable since they use a regulated boost driver
Old fenix light I got 10 years ago that was pretty stable when tested.
These are small enough and cheap enough to risk in the normal mail, otherwise it would be $75+ in shipping.
I’v sent a mail to him to, to get som lights measured.
I did a list and will let him pic what he think vill be good.
The list is this
Out of these lights witch ones do you want to test?
Sr mini intimidator
Utorch 02
Astrolux S1
Nitecore Ec11
Klarus Xt11gt
Sofirn Sp10a
Imalent Dn70 flood king
Imalent Dn35 throw king
Added several more lights to my original post (#342)
TA, is your plan to get a couple of properly measured lights from Maukka and then figure out a simple and repeatable way to reduce output on the sensor?
I would much rather we do that so that we can still use the numbers directly off the Lux meter. I realize we can just use a correction factor and do the math, but that’s not ideal to me. We can still make these tubes live up to the intended expectations.
BTW, I’m going to put off measurin all my lights for a few days when I have more time. Plus other people will be receiving theirs. We will get it sorted out. :+1:
Yes, my goal is to get a good calibration figured out first and this try to figure out a way to calibrate the spheres.
Mailing them back to me is the best way then I can calibrate them directly.
Or if you have a nice stable light you can take some before measurements and calibrate it yourself.
Or if I can find a way to add something that will adjust them that I can mail out that would be cool but after having messed with these, I doubt that is possible.
We just need to find a consistent, thin, film-like material that we can layer up.
A paper-based product would certainly be cheap, but I’m not sure of its consistency. I think you share the same concerns. Maybe we can test a variety of thin papers.
What about a lens that can be bought and stuck into the hole that the sensor mounts into? Kind of like a neutral density filter but fairly weak. I’ve got that ND filter you sent me and that thing really knocks down the lumens. I have to multiply my readings by 13.1. This should be more consistent, but the odds of getting exactly the right reduction in output seems a bit slim.
I will do some more experiments next week and report back.
