Good point. :+1: … I had not really thought about that.
Blah, blah, blah, high color rendering index is so much better etc. Cool! Good to know. Guess I’ll see when I get it. But then I also pulled the trigger on a Nitecore 2017 Tip CRI…. still can not believe the dramatic amount of difference between a CRI light and all of my previous Cree flashlights.
I prefer High-CRI, it can better restore the object original appearance, make it more comfortable for us to read and work.
Cheers ^:)
For the things I’m likely to use a flash light for, CRI doesn’t matter to me. As long as the color temperature is not too blue (beyond 6000K) I’m happy.
Combination of #1 and #3… I can certainly see a difference, but its not worth the lumen output sacrifice… Hence I am not willing to pay a a little more for it.
Personally, I buy with high CRI emitters when I can, especially since even a 25% difference in brightness is not easy to spot, but a good tint high CRI light can be extremely easily noticed.
Ive done a bit of math on the lumen outputs of the Lumintop Tool w 4000k N219b 90 CRI, 6000k XP-G2 70 CRI, 4000k N219c 90 CRI
The high modes are 80 lumens, 110 lumens, and 110 Lumens.
for me the Color Temperature and Tint of the 80 Lumen N219b is prefered. The CW makes reds look brown, the N219c has much lower R9 and a much greener Tint than the 219b. Supposedly the 219c is the same CRI as the 219b, which is true, but, thats only half the story, the R9 on the N219b is about 300% that of the 219c.
Comparing the 110 lumen 219c to the 80 lumen 219b shows the 219c is 38% brighter than the 219b, otoh, yet both have a CRI Ra of 90. But, thats before considering the RED (R9) output increase of 300% in the 219b over the 219c
now lets compare some colors on a specific light I recently had modified, on the left before, on the right after the LED swap to Nichia
(note the pics are to show color and tint, I did not take them at the same time, so the brightnesses are not accurate, the yellow light has almost double the lumens output on my meter, than the purple white light on the right.) and remember it takes a 4x incease in brightness to make a slightly noticeable difference in brightness. Doubling the brightness does not make a light Look twice as bright… anyway, I think this pic sort of demonstrates what I think might be a reasonable difference in brightness. more research required for further accuracy.
If you had to give up 48% of the lumens to gain 36% higher CRI Ra, would you do it?
Another factor is a type of CRI called the Saturated Red (aka R9 CRI). On the Nichia it is over 95 Ra, on the XPL is is a negative number, about –15. That means that the Nichia has over 500% more Red output than the NW XPL. I have never seen anyone discuss this detail, so I started a thread about it.
If Im only looking at green things, then the piss yellow light works fine. I can even tell green things apart from red things (that look brown actually).
Otoh, if there are red things to be seen, the Nichia is a Joy to behold, for me, in the way I use my lights, which is mostly at very close range and almost always below 100 lumens.
I cant wait for midnight, Im waiting to see if the drop from 0.2 lumens of XPL to 0.1 lumens of N219b is still effective to find the toilet without stepping on the cats toys, or gooey wet hairballs…
So percentage loss on a nichia swap Lumens is more than 25%, but so is the increase in CRI Ra, and so is the increase in RED CRI R9
If you had a choice to have the light on the left at 400 lumens max, or the light on the right at 200 lumens max, which would you pick?
when in doubt, the correct answer is both
Same fruit under super high CRI lighting
Yes, a 48% drop in lumens is worth it if I would gain much higher CRI.
Even then, a 50% drop in output is not really that noticeable.
LOL!
when did you sneak into my pantry?
agreed. You and I understand each other.
The rest of the world still thinks a NW piss yellow LED is not that noticeable in actual use, and we can still tell colors apart with negative R9.
Its a tint snob thing, for whitewall hunters, to focus on R9 values, like I am atm.
I have however gained a much better understanding of people with NW leds who say things like, “it looks almost like a Nichia”. That made me put my money where my mouth is. I discovered that “I cant tell in actual use unless I look at red things”. A Low R9 LED makes red things look brown. But, I have special whitewall hunters training. Im not average, or “normal”… lol
use whatever light rocks your world.
for me that means No Negative R9… this is beyond CRI Ra, which Zebra, Eagle, and Olight, have learned to “game the system”, producing “high cri” lights with low R9, green tint, and nothing like the Nichia 219b that my generation was born to love.
no judgement, just personal preferences
LEDs do not produce the same full spectrum that sunlight does, much as I wish they did. Not even all Nichias, but some Nichiast come closer to full spectrum and sunlight tint, than ALL Crees. Biased, who me?, Why, Yes! I know Red when I see it, and Cree cant show it the way some Nichias can.
btw, the N219b is extinct in the wild. There are a few left in captivity. If you want any, adopt some soon, before they are all gone to good homes.
get yours here [GB ended, news update only] Last batch of 219B sw45k R9080 and sw40 R9080 or from one of the friendly modders on that list who are stocking up.
There is the E21A and Optiolosis series of LEDs that have R9080 and R9595 respectively though to meet your sunlight needs.
BTW, another unexpected of higher CRI LEDs is while they are usually less efficient, they usually have lower forward voltages, meaning, especially with a buck or boost driver, brightness is even more stable over the runtime of the light.
yes Im very curious to see some of the E21A and Optisolis.
Im not educated enough to fully comprehend VF as you describe in relation to stability over runtime
I wondered if the Nichia had a higher VF than the XPL, but I dont have the data. I just know the Nichia lost a considerably higher percentage of brightness compared to the 5000k XPL, than a 4000k Nichia does compared to a 6000k XPG2… based on brightness differences I have measure before and after LED swaps… dont know why… more education welcome
Low VF does not mean an LED is efficient. In fact, some higher VF LEDs are more efficient than lower VF LEDs, like the XP L2 having a lower VF than a Samsung LH351D, but still being less efficient per watt overall.
Lower VF is extremely useful in two applications: light regulation and pushing as much current in a direct drive situation.
Regulating a low VF LED is much easier using any type of regulation, be it linear, boost, buck. It means more constant output. This is why I like Nichia high CRI LEDs, be it at 3V or 6V for the Nichia 144AM:
even though they are not very efficient, they have low VF, meaning constant current regulation can be very flat.
The other is direct drive: the lower the VF, THE MORE current YOU CAN PUSH TO GET EVEN MORE BRIGHTNESS!
A lower Vf means there’s more “headroom” before the light pulls out of regulation, especially with linear regulators.
Eg, take LED A with 3.1V and LED B with 3.3V. Assume a 7135 that saturates at 0.1V. Also assume both LEDs are driven at the same current.
LED A will stay in regulation until the cell is at 3.2V (3.1V + 0.1V), whereas LED B will start dropping out of regulation when the cell’s still at 3.4V (3.3V + 0.1V). So that extra 0.2V of cell life means that the light will stay in regulation that much longer.
thank you both, that helps
another variable Im exploring is the effect of the Nichia swap on the photographable Constant Current Ripple on moonlight… it is not visible flicker, but my camera sure sees something…
The LED swap did not seem to change that factor
w xpl
w sw45
What do you prefer? Quality or quantity? I like quality, i like hi cri
I prefer High Quality Tomatoes
People who don’t Hunt Tomatoes, dont appreciate High CRI. ;-]
CRI R9 differences between LEDs can be much larger than CRI Ra differences alone
both these lights are High CRI, but guess which one is the Superior Tomato Hunter?
There are lights with good tint that are Low CRI, and particularly low R9. They make bad Tomato Hunters.
I had an interesting experience with my high CRI zebralight SC5C MkII last night. It is slowly replacing my olight S1R as my EDC light. WHile I don’t consider myself a tint snob by any stretch, I do like the look of my AAA nichia lights. But I have been won over by the super easily rechargable Olight, with its significantly brighter capability. And I do use this from time to time.
I recently purchased the Zebralight to see what all the fuss was about. I have fallen in love with the UI, with direct access to moonlight, medium and high from off. Last night I was comparing the Olight and Zebralight on high (600 lumen for the Zebralight, not the 900 its capable of) and was definitely able to notice the Zebralight is a bit brighter on my neighbor across the street’s house. Then I turned to shine the lights in my backyard. Olight lights up the pomegranate tree just fine, then the Zebralight does also, but makes the red blossoms on the tree stand out. What a treat to see the colors from a distance at night.
I was surprised to read above that Zebralight is one of those “gaming” the high CRI with low R9. Wonder if mine is got more than negative R9? I think tonight I will have to compare it at closer range to my 200 lumen Manker E02 with nichia 219c and/or my Manker E01 with nichia 219b. Not sure what the R9 difference is between the three, but my pomegranate tree will help me see it.
I Love Pomegranate Trees!
this is an XM-L2 Zebra (not your model that use XP-L2) compared to an aaaTool w N219b 4000k 9050, (same LED as the Maratac AAA)
Only the NW and CW Low CRI lights have negative R9, I just fault Zebra and Olight for using a Cree High CRI, instead of the Nichias, that have better R9
But I know why they choose Cree, they have more lumens…
Green Lumens are brighter than Red Lumens
iow, lights with tint above the BBL tend to be brighter than lights with tint at or below the BBL (a gross generalization,)
