Yes, interested
This is great, thanks!
I really need to get in on this, please add me to the list for 1 pc.
Great work DBSAR, thanks for all the time and effort you’re putting in on this!
Don’t know why I’ve ignored this for so long but I really like the way it’s evolving.
Nice! I had been thinking about looking into doing something like this on my Q8, can this mod be done to a regular stock Q8?
Jumping in for a 2nd one please.
Yeah, it was a stock Q8 before he modded it.
The standard Q8 tail cap metal is to thin, i had to add a 1/8” thick aluminum plate inside the tail cap using JB-weld to make it thick enough to thread it so it can hold onto the tripod mounts.
Hi CJ, you currently are on the list 3 times,
174 CJ Avlis
263 CJ Avlis
447 CJ Avlis
Should I add you for a fourth?
What I am planning on doing in the interest list going forward is providing it to DBSAR sorted alphabetically by user name, so you can easily look in the first post and see where you stand. This would be updated every so often, maybe twice a month, or more often if folks want. It is pretty easy to do for me, the magic of a spreadsheet. I’ll add a link to it below, but it seemed like for some reason several folks are having problems seeing the numerically ordered interest list, so don’t be surprised if you have problems with this one as well. Just ask for permission to see it if you need to.
I’ll continue to keep up the order of interest document which I have been linking to for the past week or so as soon as people request to be added, but will update the listing in the spreadsheet sorted by peoples name just periodically, like every other week or so (as mentioned above). Hopefully this helps folks know where they stand in terms of how many lanterns they have showed interest in to date.
That would be awesome idea
The list I created above is functional, but I am reworking it a bit to be easier to read. Hope to be done in a couple days or so.
So is the cooperation with Thorfire working out sofar?
Anyone know if this lantern use unprotected or protected ? I want to start shopping for some protected 18650 if it does…
It will be using unprotected of course.
Just use any 18650 you have around, and it will work, as it uses the BLF Q8 battery tube, meaning both unprotected and protected cells will fit. And it has low voltage protection, meaning I would just use unprotected 18650s in this case.
Do you think it will be ok to use unprotected 18650 for the normal people ( newbie) ?? I am fine with the unprotected…
Yep. Low voltage protection is there, like with the Q8.
And since all modes of the lantern are going to be regulated low power modes, protected cells are not really necessary.
I spoke to Barry a couple times so far via PM, once i can get a cross-section drawing done, and find somone who can to CAD design for the lantern to provide to them, then hopefully we can get it rolling more with them.
It can use both. (but will need button-tops though)
