LuminTop ODL20C Small throw flashlight
ODL20C is a throw flashlight by utilizes a Cree XHP35 HI LED and adopt the aluminum flat and deep reflector, it emits a max 2,000 lumens output and creates an 860 meters long-range throwing distance by running on a 26650 cell. Five output levels plus Strobe, SOS and Beacon modes are more fit for various lighting demands. The USB Type-C charging enables a 2A current charging current and it takes only three hours to fully charged the battery. The humanized breath lamp allows easily locate the flashlight in the dark. Lock-out function, charging indicator, low battery reminder, tail standing ability and IP68 classification protection etc. makes ODL20C indispensable in your searching, rescuing, hiking activities and so on.
Features
  1. Utilizes Cree XHP 35 HI LED with a lifespan of 50,000 hours
  2. Powered by one 26650 rechargeable Li-ion battery
  3. High efficiency circuit with a max runtime up to 9 days
  4. Smooth and deep aluminous alloy reflector creates a max 860 meters beam distance
  5. 5 output levels plus Strobe, SOS and Beacon with a max output of 2000 lumens
  6. Humanized breathing light inside the switch, indicates the light location in the dark
  7. Durable USB Type-C charging with 2A max charging current, 3 hours to fully charged a 5000mAh Li-ion battery, fast and convenience
  8. Red and blue charging indicator visually shows the charging conditions
  9. Size: 151*59*35mm, Net weight: 300g (excluding battery)
  10. One side switch operation within one hand control
  11. Lock-out function prevents accidental activation
  12. Enhance cooling fins ensure a comfortable holding
  13. Low voltage indicator reminds to change or charge the battery in time
  14. Flat tail cap with tail standing ability to serve as a candle
  15. Toughened and ultra-clear glass lens with anti-reflective coating
  16. Made of aerospace-grade aluminum alloy, premium Type III hard-anodized anti-abrasive finish on the surface
  17. Waterproof to IPX-8 standard, 2 meters underwater (ensure the waterproof cover is in sealed condition)
  18. 5 years free repair, limited lifetime warranty
Familiar rabbit
Front, built-in red, blue light side switch
USB Type-C charging interface
LumibTop OD Series Brothers (ODF30)
Each of his duties
SDmini welcomes new members
All LuminTop made
Use a 26650 lithium battery, need to purchase
Say goodbye to the sun and prepare to test at night
ECO (moon)
Low
Medium
High
Turbo
Animation:
chart:
CREE XHP35 Hi has long shot ability
Smooth light cup
Put a piece of hard plastic on the outer layer of the plastic and the switch feels better
Charging instructions
Full charge indication
Low voltage indicator, animation:
Tail double spring
Positive copper plate and a black insulating gasket
Charging port waterproof cover
High quality
High quality
Deep ditch
Photo I
Photo II
Photo III
Photo IV
Photo V
Star Night Shot
Thanks for watching
Great pics, looks like a useful light! I love 26650 lights.
Could you tell us about the UI? I like the light but I won’t buy it if needs a long click to turn on/off
I am just guessing it is like most Lumintop UI’s. Single clicks for mode change, long click for off. I like Lumintop’s UI. Some people do, some people don’t. Maybe I’m just use to it.
XHP35 HI driven about as high as it deserves, nice cooling fins. Type C. Reflector doesn’t look too smooth, but throw seems ok.
Nice review! Thanks.
(led centering seems not Lumintop’s strongpoint)
Thanks for the great review! :+1:
Nice photos
Yep led is off center. :disguised_face:
Being off center, does it affect throw or brightness much?
not that u notice but a flashlight at this price range should be perfect centered i think. even convoys light i have have better placed leds.
yes it will affect the throw and you can see rings when shine on the wall.
Good to know, thanks.
Interesting, never had a lumintop flashlight before. I wonder if their 2000 lumens turbo is real or not? That would be brighter than my V6.
very nice pictures!
depends how hard the xhp 35 emitter is driven, a little over 2000 is what u can push it out anyways, not even the blf gt or astrolux mf02 or all those that have this emitter goes very much above 2000 lumens.
If it hits 2000, then still about double my UT02 output which is great if it really could do that.
this has 5 year warranty?
5 years free repair (normal use)
