Lumintop ODL20C USB Type-C Rechargeable Thrower [New]
ODL20C is a high-intensity throw flashlight designed for outdoor searching, rescuing, hiking activities and so on. Utilizes Cree XHP35 HI LED and runs on one 26650 battery, it emits a max 2000LM output and reaches a far distance up to 860M. USB Type-C rechargeable with charging indicator, low power indicator, breath lamp, IP68 rated protection etc, all makes it indispensable in your kits.
More details: http://www.lumintop.com/odl20c.html
MSRP: US$79.99
Any tip about the UI?
I would love to review this one :smiley:
It is nice to see that innovation is currently full-steam ahead! Yippee!
im sure u will mr. x3 :smiley: nice light lumintop is stepping up now.
I’m glad it uses USB-C! However there is still a glaring flaw… How should I set it down on my night stand?
If I set it on its head, there is no crenelated bezel. I may accidentally leave it on…
If I set in on its side, it may roll away…
Setting it on its tale may be the best option, but not the most stable…
Crenelated bezels and anti-roll designs are some basic things that light manufacturers used to incorporate. I feel that in many ways we have digressed. Now I sound like an old grouchy man, but until these basic things are fixed I won’t be buying this light… Sorry :cry:
You could just look at it and see if it’s on before setting it down. Works for me.
Look similar to utorch UT02 and manker :slight_smile:
Breathing mode is alike too :slight_smile:
Hello, please check the UI :slight_smile: :
Can you get to Turbo through two quick clicks from the LOW-MID-HIGH modes? Because it does not follow from the diagram. If so, being in Turbo, one click returns us to what mode?
Looks just like the ODF30 but I think they made the diagram a little confusing. Double click to turbo from low, mid, or high. Then single click to get back to last used mode before turbo.
Yes, you are right.
Turbo can be accessed by two quick clicks from low, mid or high (any one of them), and one click from Trobo will return to the previous output level. For example, when you get into Turbo on Med, then another one click will return to Med.
Yes, that it is.
When will this flashlight be available for purchase? I love my Lumintops so I can’t pass this one up.
I wish it came in neutral white, 21700 and had a low moonlight mode….
What is the real average throwing distance of this Lumintop ODL20C? The advertised distance is max 860 meters which sounds high. The all new Thrunite Catapult V6 is just above 750 meters of throw.
We will only find this out when it is released and someone does real world tests.
What is the inside diameter of the reflector?
ODL20C is now available on our Lumintop online (China): lumintoponline.com
and will need some days for Amazon.
The inside diameter of the reflector is 50mm.
