any interest in 2*AA flashlight?
Show us some drawings of the light. 2AA are especially nice for non-flashaholics!!
Yes I am interested in that type of flashlight.
Will those two 14500 cells work in series, i.e. 8.4V to achieve the 1.200 lumens or will they work in parallel (2p), so one gets the double capacity? Most high drain 14500 cells lack sufficient capacity to provide enough energy for high lumen output.
YESS!!!
but I prefer improved performance/efficiency with 2xAA Ni-Mh please…
I dont want Li-ion.
And if it has USB recharge even better!!!
I got thinking about something similar to the TO1 …a flashlight that could be used with 1 x AA or 1 x14500, and came with an extension tube to make it a 2 xAA. I’d like extended runtimes rather than the highest output possible.
I also second samgalax’s idea for ‘performance/efficiency with 2xAA Ni-Mh please’ and usb charging.
I’d like it to tailstand and be bundled with a frosted plastic sphere so it could be used like the nitecore LD12.
Could be a great everyman’s blackout light.
Sorry if I went a little off topic …that’s my two cents.
Flashlights for the AA size are only relevant if they are designed for NiMh batteries (and Manker makes good boost-drivers so that should be do-able) . If the performance is dependent on li-ion 14500 cells, a 18650 flashlight will be superior in almost all aspects.
Usb recharge the NiMh would be great because there are not much ones that can recharge nimh. Others offer liion usb recharge.
Charging nimh in series is more expensive but more useful for me.
And the usb port NOT IN THE THREADS please!
The usb must be OUTSIDE the flashlight with a rubber cap.
Is very bad to have to unscrew the head to reveal the usb port
I agree with all your points! The Armytek Prime A1 Pro and A2 Pro tubes are swappable so you can use either 1xAA or 2xAA for more output. I think the Thrunite Archer 1A and 2A works the same. Usb charging would be nice addition, which would make this the one and only usb rechargeable AA light. Tail standing would be super useful especially during blackouts. Frosted cap to turn it into lantern would be great too for a AA light.
USB rechargeable nihm with a nice form factor. I would like to see two batteries next to each other, keeping the light short.
That would be perfect: a Sunwayman D20A-killer!
Interested! Please make it pretty! :smiley:
I would like to see this one :wink:
I assume it would be different from the Manker E12, right?
A nice form factor, and a nice UI (quick access to the lowest mode and shortcut to turbo, are desirable at least for for me), besides all the performance on different types of batteries, would make it a great light with Manker’s quality!!
I don’t see the point in 2x14500. Anyone wanting to use lithium-ion, would be better off just going for a 18650 light. But 2xAA is a nice form factor for general use. Decent run-time compared to 1xAA, but still small enough to carry in a jacket pocket.
I like my T01 (1xAA), but I tend not to use my 2xAA’s much anymore. Probably it’s because a 1x18650 is a better alternative, for those that don’t mind lithium-ion cells. But for those that want to stick to AA’s, I think a T02 would be a great fit.
Interested in 2xAA or 2xNiMH with decent performance, for non flashaolics.
Forget 2x14500. They are expensive compared to their capacity.
A short tube for just one AA would be a nice option.
USB charging for NiMH would be great.
Please manker…. make a good 2xaa with ability to recharge 2x NIMH via micro usb or usb type c…
But not having to unscrew the head to acces the usb port. I mean…. preferably usb port with a rubber cap to avoid water/moisture.
And forget 14500.
please please!
800 lm??? Please, stop this stupid hunting for hundrets of lumens! I´d prefer 350-400 lm without step down and with good runtime(more than hour of 400 flat regulated lumens would be fantastic).
There are already plenty of 2xAA out there that does that already. High powered 2xAA is limited to only Armytek Prime and Partner A2.
Yes, the Armytek Prime A2 will already do what he wants.
I agree with samyy. 800 lumens seems over the board for a 2xAA light. How useful can it be if it drains the batteries in seconds and you’re left with a dead light or very little runtime after that? My interest in this kind of light is for friends and family who have no clue about Li-ion cells. They are usually plenty happy with a few hundred lumens.
Forgot the model name, but I had exactly that light in mind. Thnx! @Manker, I would buy something like this immediately.
