Seems to be a very tempting choice after emitter swaps, thank you for showing it.
Looks very nice.
I would have preferred the batteries to be in parallel though for extra safety and so it could run on less than 3 cells if needed.
Wow
Like the light but love the review.
I did not new info could be added, excellent work.
Its not fair to compare the D4 with 219 (comparisons for efficiency should be using the same emitters, dont ya think?)
The XP-G2 CRI70 and 219C CRI80 are quite comparable in efficacy.
But you are right, the linear driver in the D4 burns off the extra voltage as heat, which makes the 219C look even worse since its forward voltage is lower. But the buck driver in the G180 would still be more efficient given the same emitters.
I test it on Sanyo NCR18650GA 3500 mAh:
(Strange light in my arms...: YLP «Gryphon» G180 | Яркий Луч «Грифон» G180)
That looks like a really practically sized light. Looks wise the Manker MK34 is more appealing but this one has a much better UI. I wonder how hard is it to swap emitters on this light so you can use 219B/C in it. Would have been better if they up the turbo to match the MK34 though. Btw, excellent review as always! I enjoy reading them.
Left: XP-G2 4000K by stock,
Right: Nichia NVSW219C SM503-D240-L1-R9050 (5000K CRI > 90)
Lux (maximum) from 1 meter:
level | G180 by stock | Nichia 219C |
level 4 | 12 250,00 | 8 810,00 |
level 3 | 8 340,00 | 5 920,00 |
level 2 | 3 320,00 | 2 070,00 |
level 1 | 670,00 | 458,00 |
level moonlight | 29,30 | 15,08 |
Nichia 219C version have more smooth beamshot.
I’m also make version with HI-CRI LED Samsung LH351D SPHWHTL3DA0GF4T0Q6 (4000K, CRI > 90). Photo and lux coming soon.
Is the only source to buy this flashlight the one in Russia or are there any plans for a sale via Banggood, Gearbest, Fasttech, HKEquipment and so on?
Just buy yourself a Noctigon Meteor 219C, it is 98$ now on intl outdoor:
https://intl-outdoor.com/noctigon-418650-meteor-m43-p-864.html
Meteor too fat, too short, too overhead interface.
s. all new Meteor have defected body - problem with knurling
Thanks for the review. Refreshing to see no silly lumens for 30secs mode! A tripod thread would be a good addition.
Tell us more about these „defected bodies“, please. I just bought a Meteor M43 with XP-L Hi and I did not find any defects on the knurling/body so far. I only found out that the new body has only one hole for a lanyard whereas former versions had two holes.
[quote=FlashTom]
You can see it on photo.
Sorry, I don‘t see any real problems on that Meteor. Can you please pinpoint the defective part?
It’s not really defective, but rather that some knurling is not well done on the top and bottom parts of the light.
Could be just an issue on your light @MaksVasilev.
Today I received a flashlight M43 and …
I am very disappointed with the product. I counted on top quality and got a flashlight that is not centrally set. The torch I got, has diodes not symmetrically in relation to the switch and it irritates me very much.
Backstage of making a beamshot:
Target - small photo reflector ⌀ 105 mm, distance between light and target 1,0 m
Sansung LEDs G180 have very smooth light and very wide and homogeneous in center. Also this have little less red tint in light.
Compare with Manker’s MK34
Other
Sample photo from nature.
Pairs of photo have differences in White Balance for compare only light distribution and wide of spot. Left column - Nichia wich WB=5000K, Right column - Samsung with WB=4150K
Gif from this:
Same photo as before, but all in one White Balance = 5000K, for real color of light comparation:
Nice high quality photos. Too bad the LH351D isn’t being driven harder cause the lux would be a lot more comparable that way.
Is there any resistor mod or something that can be done easily?
Table in previous post in lux, not lumens. Samsung have more wide beam and with same lumens from flashlight have less lux in one point.
