Review for Thorfire TG06S
Review copy provided by Thorfire via Amazon U.S.
The TG06S is Thorfire's latest 1xAA/14500 light and also their newest product. The TG06S is a tube-style light which utilizes a Cree XP-G2 in a polished reflector.
The official product specifications:
TG06S LED flashlight is the upgraded version of ThorFire TG06 flashlight. TG06S has 5 modes: High-Mid-Low-Moonlight, hidden Strobe. gives out MAX 500 Lumens
Extremely Bright Mini Light: TG06S flashlight uses single XPG2 LED, gives out MAX 500 lumens when powered by premium 14500 battery(NOT Included).
Multi-functional Light: High(500LM) - Middle(200LM) - Low(50LM) - Moonlight (1LM ) and Strobe , perfect for daily different applications
Durable: aircraft graded aluminum alloy to ensure durable, sturdy, non-slipping performance
Package Includes: 1x TG06S flashlight; 2x spare O rings; 1x manual and helpful customer services.
New Features on TG06S:
1. More Modes: When using premium 14500 battery, the brightness can be High(500LM) -Middle(200LM) -Low(50LM) -Moonlight (1LM ), and Strobe(500LM);
When powered by AA battery, the mini light gives out High(150LM) -Middle(80LM) -Low(20LM)-Moonlight (0.5LM ), and Strobe(150LM)
2. Very easy operation. Fully press the turn on/off, tap to change modes, double tap to activate Strobe mode for emergency.
3. The lightweight makes the newly designed ThorFire TG06S fits easily into your pocket, backpack, purse, or tool bag.
4. With one considerate metal clip, you can clip it to your shirt pocket.
5. It is great for multiple indoor and outdoor applications including searching, camping, hiking, or even used as an emergency light during a power outage.
6. One cool thing is that the O-ring behind the lens glows in the dark, which makes it easy to be found in the dark.
Warranty:
ThorFire promise to offer 40 days money back and worry free customer services, if you encounter with any question, please contact us.
Technical Details
Item Weight: 1.6 ounces
Product Dimension: 4.3*2*1.6 inches
Thoughts:
The light arrived in a very well no frills packaging with the light itself inside a bubble wrap along with its metal clip installed which
was sitting in a black foam for additional cushioning, has 2 spare O-rings, and the user manual.
The TG06S has smooth black anodizing. It has very good CNC and with all the logo of the manufacturer as well as the model number of the
light can be clearly read. It has a subtle diamond knurling in both the body and tail to provide good grip. It has a smooth hexagonal
cut ring on the base of its head to provide anti rolling for when the light flat sitted. It can stand both from the head or the tail on an even surface.
It has a good green glow ring placed by the lens for easy finding in the dark.
Both the threads on this light are squared and smooth, very well lubed as well. The tail thread is also anodized for a mechanical lockout use.
The clip has a SS finish and can both be installed in the tail or the head end for facing the light outwards depending on your purpose. It is very secure and tight
which is relatively hard to accidentaly remove.
The TG06S can be powered either by a AA battery or a 14500 cell, althought the highest lumen output can only be achieved when using a 14500 cell.
The operation modes of this light is pretty simple and straight forward. The light uses a standard reverse-clicky in the tail which utilizes full and partial presses.
Output is ordered H -> M -> L -> ML. There is no mode memory so the light always activates on High. Strobe is activated by double clicking when on at any mode. Thers is
also a slight split second delay whilst changing modes.
The TG06s is moderately Throwy. The TG06S uses a domed XP-G2 combined with a polished reflector so the hot spot is relatively tight with a slightly defined corona that transitions nicely
with a reasonable amount of spill.
The color temperature of the light is Daylight at around 5000-5500k.
Overall, the TG06S is a very well built AA/14500 edc. It is very compact and light, very bright as well as a good spacing for the modes brightness levels. Definitely a good value for money
in terms of finish, performance and build quality. Another awesome light from Thorfire!
Below are creative shots of the light (I will be editing this post and uploading beam shots later):
Thank you for reading! Accepting constructive criticism and suggestions. :)
If you want 50% off coupons for this light via Amazon, please like my page and pm me there www.facebook.com/torchesinternationale I have 3/5 remaining.
Sacrileizei, thank you for the coupon code! As a result, I just snagged an extra copy of my favorite EDC flashlight from Amazon for $8.25! I will try to monitor your Facebook page occasionally from my wife's account to see what is new. Thanks again!
FWIW, I always carry my Thorfire TGO6s in this flashlight holder to keep my pockets free.
My pleasure ActiveAl
oh I just realized your flashlight holder just costs a little bit more than the light you just bought :smiley:
Hi guys, here are the last 3 discount codes for 50% off Amazon, it is a one time use, so if it doesn’t just try the others, if none of them works please say so, so others would know it is all claimed. Discount codes provided by Thorfire. Enjoy!
LKGF-8FY2EK-AHVUER
LKCX-8MYRMF-PW5SP3
LKLT-S39GRF-RHFSFS
I used code LKGF-8FY2EK-AHVUER.
Thanks sacrileizi !
My pleasure
I used LKCX-8MYRMF-PW5SP3 for 3 of them- thank you so much! Thorfires S70 and the Q8 build have held a place in my heart for some time, hope these are as good.
Wow I didn’t know that you can purchase multiple lights for 1 code. But, good for you, I’m sure you won’t be disappointed as I sure am not! Cheers!
Sacrileizei, received my new TG06S from Amazon a week ago and I'm lovin' it Thanks again!
Awesome! I’m glad you do. My pleasure ActiveAl
