July 9th New Arrival:
1.Xtar VC4 18650 4-slot Lithium-ion Ni-MH Battery Charger - BLACK
https://www.gearbest.com/chargers/pp_009676245583.html?wid=1433363
Main Features:
●Four slot
Compatible with most rechargeable lithium-ion batteries and nickel-chromium-nickel-metal hydride batteries.
●LED indicator light design
Real-time battery voltage display, each cell voltage is approximately 10 percent of the battery capacity.
● LCD display, innovative turntable style
● Charge current display, suitable for all 5V USB power supplies
● Four-slot independent
● 0V voltage activation function, over-discharged battery
● 0.5A and 1A charging current
● Overcharge / overcurrent / overvoltage protection
2.Xtar Rocket SV2 Smart Quick Charger - BLACK
https://www.gearbest.com/chargers/pp_009806508920.html?wid=1433363’
Coupon code: IT$LEDSV2
Main Features:
●Double slot
● LCD screen displays battery power, charging status and charging current
● Automatic identification for simultaneous charging of lithium-ion and nickel-metal hydride batteries
3.lii-500 18650/26650 Lithium Battery Charger with LCD Display - BLACK
https://www.gearbest.com/chargers/pp_009343206925.html?wid=1433363
Main Features:
Different specifications of batteries can be charged simultaneously such as 18650 / 26650 / AA / AA / A batteries, etc.
4 charging slots
Features 4 charging current regulator, 300mA / 500mA / 700mA / 1000mA. Each channel works independently
LCD screen
Updates every second to keep you in the loop on the charging process
Quick test mode
4 channels detect the battery capacity quicker than the Nor mode Short circuit / over-current / over-charging / over-discharging / reverse polarity protection / temperature control / charging between 1.65 - 2.2V / bad battery recognition and activation
DC input voltage: 12V / 2A
Car charger input voltage: 12V / 1A
Please NOTE: batteries are not included.
4.Allmaybe TC2 Lithium-ion Battery Charger - BLACK
https://www.gearbest.com/chargers/pp_009360164937.html?wid=1433363
Coupon code: IT$LEDTC2
Main Features:
●Double slot
● It can charge two batteries and one external device at the same time.
● Shell made of ABS fire retardant material, excellent heat dissipation design
● Ingenious display
●0-volt activation function, to save over-discharge lithium-ion battery
●Automatic identification, intelligent selects its appropriate charging gear ( 0.5A / 1A / 2A ) for battery
●The sub-capacity test function, through the release of capacity, accurately measure the actual battery capacity
