Yup, and a decent size. Like I mentioned, the footprint is nearly identical to the XP-G3. Technically, itās offered in two footprints: A120 (main size) and B120 (smaller pads). Click for larger images.
Luminus SST-20-W A120 footprint:
Cree XP-G3 footprint:
Edit: I see that the dome on the SST-20 is smaller than the XP-G3: radius 1.3mm vs 1.53mm, respectively. Which makes me wonder if it has a small die? Also, it looks like it has a similar structure as the SST-40 (that is, not a flip chip design) which is reasonably good news for dedoming prospects. Now to find a vendor for theseā¦
Black flat is kind of a weird led to work with , so even if performance is 15-20% better than xp-g2 it will be awesome
Osram LE UW Q8WP is awesome from my point of view (same performance as OBF but double lumens) but costs 10+$ per led , compared to the 1$ of sst-20 ( link )
Cold, yes. Colder than I usually prefer. But at least if itās like the SST-40 (as is expected), then it should be a pure white, not blue or purple. I put a few dedomed SST-40ās in Convoy L2ās and actually donāt mind the tint for a thrower.
I pulled the trigger on the Aliexpress listing last week. I canāt wait to see how they perform sliced / dedomed - should be good. Not that I really needed 10 of them :person_facepalming: but at less than $1 each, oh well
Iāll try a sliced one in my Amutorch JM70 (now a dedomed XP-L) when I get them. If it improves throw I might test it in my Olight M3XSā¦
Will definitely update here
