Much appreciated it!
he will save the day
Here is a short video showing when i press in on the dome in the corner of the bad LED, it flickers on for a second:
My best guess, not enough solder during reflow.
Interested for 1!
I want to thank everyone that put time and effort into this project. I really appreciate it.
Looks like you’re good for now, but Digi-Key actually has 8 varieties in-stock with no minimum. Different CRI’s (70-80) and CCT’s (3000-5700) available. Link
Which is problematic. No 90CRI available.
Also, we have AEDe which can supply Thorfire with full reels, so no problems there too. Hopefully of course
:person_facepalming: Sorry, just catching up on the thread. Didn’t realize that 90 CRI were being used. Carry on!
There was, I removed it and re-flowed it again on to a standard 16mm star & it had the same problem. Likely a defective bad LED.
That makes sense. I’ll probably get two or three of your’s then.
put you down for two barretttx (768 and 774) until you say otherwise, and added Basuini888 at entry 772 and 773 also.
Also added entry 775 for slowtechstef
So who is going to get lucky 777?
I sent him the LEDs. The project can continue uninterrupted.
Here is what i found: > The LH351 4000K High-CRI emitters, measured to be more efficient, and have a higher output than the XP-L 3000K at the same current & test perimeters.
- (two) Cree XP-L 3000K ————————— / 630 lumens / 1.09 amps / High-mode ( maximum of the 5-mode group on 3-7135 AMC chips)
- (two) Samsung LH351 4000K High-CRI——/ 745 lumens / 1.07 amps / High-mode ( maximum of the 5-mode group on 3-7135 AMC chips)
My name is cu42 and I approve of this message!! high CRI fan here.
I never put much thought into whether any high cri could be more efficient at medium outputs since as a newb I am always focused on the max numbers.
I was originally thinking the warmer 3k was the way to go for a camp lantern, but now wondering if high CRI at 4k would be more desirable than lower cri warm tint? Is there even such a thing as warm high cri?
Last I checked, daylight tends to be around 5500K mid-day, but it gets warmer in the morning and evening as the sun gets low in the sky. At sunrise/sunset it can be below 2000K. Moonlight tends to be around 4000K, but is generally too dim to activate cones for color perception.
i have seen this project right now.
if it is possible: im very interested depending on price
This is correct.
The Kruithoff curve shows in what brightness range a specific CCT is perceived as comfortable. Sunlight with 5500K is comfortable because it is so bright! It also shows why cloudy days with very high CCTs and rather low brightness can seem uncomfortable.
Since lanterns usually produce floody light with low lux numbers, they need to have a low CCT <=3500K to be comfortable. A perfect lantern with a large brightness range would adjust its CCT with the brightness.
This is of course all somewhat independent of CRI. The CRI should be high regardless of the brightness and the tint should always be close to the BBL.
Great information on CRI
So will their be a test
Great work by all on this project.
Thank You very much.
I thought CRI had more to do with the visible spectrum and nothing to do with color temperature or sunlight…
please count me in (interested)
