This is basically a manker U21 or Utorch UT02. I am hoping with the higher lumen claim that it’s better driven.
electronics components from manker?
interested
The host is most definitely from the same supplier as the Utorch and Manker. Slightly different battery tube grip cut but if it’s not it’s a clone. My point is, I hope it’s better driven than the Utorch UT02 offerings of late. I have both the Manker and Utorch UT02 that I bought about 18 months-2 years ago. They are bright and nicely made but the current Utorch UT02 offering has a weak switch and noticeably less bright.
I like Lumintop products. I have several of their lights like the TD16 and TD15S and like them a lot! I hope this light doesn’t dissapoint
Interested thanks
Interested
Interested
two questions:
is there ever a heads up when these group buy deals expire?
Also, no mention of the XHP 35 LED tint
- At least 2-3 months if nothing bad happens.
- There is only one tint. Based on the product pics, it should be cool white.
AFAIU cool white and throw do not go well together because of scattering of blue wavelength… Why then? :person_facepalming:
Interested
Interested please send a PM
I brought CW MF04 out the other day. It is actually not to so bad with naked eyes. If you are comparing a long distance, CW does throw further when u compare with same XHP35 HI class NW emitter. However, NW will have the advantage for beam quality and CRI.
Ordered one. Thank you!
Interested
Interested
Interested
Intrested,
this will make a good replacement of my 900lm. ut02
900lm? Your UT02 from which batch?
Intrested, this will make a good replacement of my 900lm. ut02
Interested
