Maybe ask pflexpro about sending him some lights to test for standard/calibration lights?
Or maybe he would have a stock 7135 Convoy light he could just test and send with a test results sheet.
The C8 might be a light I can compare with. I’m running a different emitter, but color should be the same. I got:
Convoy C8 XM-L2 U2-1A - 1330 @30sec (a little better than my previous reading of 1310)
So I’m getting a higher output. The two bin codes show mine should measure about 15 lumen higher which is virtually the same. If I use a .65 correction factor, my reading is about 120 lumen higher than yours (860 to 740).
Pretty interesting. I wonder if there is a performance difference due to the battery? I’m using a protected KeepPower Sanyo 3500 GA pulling 2.66A. Same amp draw and output on a button top 30Q at same voltage.
I think he is just excited to try out a new toy. It is not a problem to post the numbers as he is, they are just not very useful without more information.
Hmm, that is possible. Although doesn’t look like he is very active, he has not logged in for almost 2 months.
It also would seem kinda strange to not just buy one of his lights, which I suppose I could do but looks like the cheapest light he offers is an S2+ for $50. Which is ok but I would really prefer have more then 1 measured light to give better comparisons. Although $50 is hard to swallow right now seeing as I just had to buy a new soldering station.
It is an option to consider though, I just sent him a message on here, not sure if that is the best way.
Also, just so everyone knows, unless otherwise stated, my numbers are generally between 5-10 seconds. That is long enough for the output to level out somewhat in most cases yet not heat the light up too much for future readings or drain the cells too much.
Many times I can need to take several readings within a few minutes and having to swap batteries and wait for it to cool down each time would make this process take way too long.
I think the PM was probably the best way, My thought was if he had a stock light sitting around he could test and sell for maybe a little over the actual cost. I think he would understand you don’t really need one of his lights but just something to use for a calibration standard. My thought was maybe he would be willing to help since he’s a member and not that far away. (Georgia?)
“My testing: I use the FL1 test procedures, but my sphere is not ANSI calibrated but is calibrated using a number of ANSI rated flashlights. Since I make customs, I don’t have a production run of flashlight to test. I test each flashlight I build and report the output for that light. I believe this gives you the most accurate output rating for the actual flashlight you will receive. Many of my buyers have commented on how much brighter the PFlexPro flashlights are compared to the ones they have that were supposed to have similar output. I also provide full information on my methods of thermal management and construction details in addition to the actual output -I believe you have the right to know what you are buying.”
The 120 lumen difference is from using a .65 correction factor. We all know the stock C8 does not put out 1330 lumen so I adjusted the numbers down. (BTW, I might have read 1140 was your reading)
1330 = 860
1150 = 750
Difference of 110 lumen in real world.
If we use a .70 correction factor the difference is 125 lumen (930 and 805). I hope this makes sense.
I am not putting any material over the sensor. These are raw numbers so they can be adjusted later on once TA has an official correction factor.
What’s interesting is that Cree rates their bin numbers with a 14% deviation and then TA Tubes are calibrated within a 10% deviation. So both of our outputs fall easily within that range. Even if our tubes were perfectly matched, I might have an emitter on the higher end of the bin scale and you might have one on the lower end and it just fits within Cree’s 14%.
Yeah, it’s not very useful and I don’t mean to sound harsh. I just don’t want other people to get confused by it.
Handing out these Lumen Tubes is kind of like handing out a loaded gun. Some people know how to use it properly and will holster it with the safety on and other people will just run around shooting it off in the air with no regard to others.
That might be a bit of an extreme anology, but I think people should be more responsible when posting lumen results. You never know when an outsider might Google search for a flashlights output and go to a persons post that shows out of context numbers.
I know we are all amateurs here and these tubes are not meant to be a replacement for a proper integrating sphere (Ozzy), but I would still like to see us set some standards. Such as saying whether these are raw numbers from the TA Tube or if it has been corrected by XX%.
“I want these tubes to reduce the chaos in the world, not to create more.” - Philosophy of the day by JasonWW
You didn’t sound harsh Jason & I understand Newlumen’s excitement also…. nothing wrong with that.
But any data, without stating the parameters under which it was achieved; becomes random & meaningless. And that applies to most anything and anyone who does it.
It can be easily misinterpreted by someone looking at a random post where the parameters under which the data was achieved are not stated.
No harm, no foul. Maybe we can all be more responsible in what we post so as to contribute useful data.
We dont know the real correction factor… i dont have an integration tested light to calibrate… so jason, my 4” tube correction factor would estimate around .84… without plastic! Lol.
Just curious, what are you basing that estimate on??
IIRC that is the highest correction factor mentioned yet by anyone, seems like TA mentioned a correction factor of around .70 would get these in the ballpark until he could get a more correct one worked out & established from known light sources.
As now i only have fenix tk15 rated 1000 lumen. This light could be 1004 lumen, 1050 lumen, 1090 lumen, anywhere from 1000-1096 lumen… we are not suppose to be using stock light to calibrate…
Personally, I do not have a light with verifiable tested lumen output. So anything I did would just be a shot in the dark… a crapshoot so to speak.
So, therefore I will just wait until the verifiable correction factor data is worked out by TA and/or the guys who actually have verifiable lights to test.
Although after reading the PFlexPro site yesterday, I may spring for one of those tested & verifiable lights in the not to distant future.
Honestly until I am able to get some calibrated lights for more exact numbers (or if someone else has some like that), I would not really worry about getting it exact.
Just post the as-is numbers and maybe some numbers with whatever method you found got them in the right ballpark.
All I am looking for now is the average correction factor among the spheres at this point. So far it is looking well within my goal tolerance levels but more data is always good.
You are welcome to adjust your sphere however you want and to whatever you want for now. Once I figure out a fix then everyone can apply it and compare readings evenly (well, within ~10-15% or so, with everything factored in).
