The host is most definitely from the same supplier as the Utorch and Manker. Slightly different battery tube grip cut but if it’s not it’s a clone. My point is, I hope it’s better driven than the Utorch UT02 offerings of late. I have both the Manker and Utorch UT02 that I bought about 18 months-2 years ago. They are bright and nicely made but the current Utorch UT02 offering has a weak switch and noticeably less bright.
I like Lumintop products. I have several of their lights like the TD16 and TD15S and like them a lot! I hope this light doesn’t dissapoint
I brought CW MF04 out the other day. It is actually not to so bad with naked eyes. If you are comparing a long distance, CW does throw further when u compare with same XHP35 HI class NW emitter. However, NW will have the advantage for beam quality and CRI.
