ENEDED
  1. At least 2-3 months if nothing bad happens.
  2. There is only one tint. Based on the product pics, it should be cool white.
AFAIU cool white and throw do not go well together because of scattering of blue wavelength… Why then? :person_facepalming:
Interested
Interested please send a PM
I brought CW MF04 out the other day. It is actually not to so bad with naked eyes. If you are comparing a long distance, CW does throw further when u compare with same XHP35 HI class NW emitter. However, NW will have the advantage for beam quality and CRI.
Ordered one. Thank you!
Interested
Interested
Interested
Intrested,
this will make a good replacement of my 900lm. ut02 :frowning:
900lm? Your UT02 from which batch?
Interested
Seller has sweeten the deal for US!
Refresh my pm to view our NEW PRICE!!!
There has been some adjustment to the GB. Current deal validity period will be much shorter than usual.
interested
interested.
It is basically a high powered version of the Manker U21 or Utorch UT02. It is a thrower for sure with a 58mm SMO Reflector and it is fairly deep. I have lower powered versions from Utorch and they throw very well with useful spill. The lumintop version is likely to be much more impressive.
In comparison to the specs from Manker of the original U21:
1300 Lumen, 124,000 cd, 700m of throw distance. I found these numbers pretty accurate. It’s a good light.
Lumintop ODL20C Specs:
2,000 Lumen, 184,500 cd, 860m throw. A nice add is 2A built in charging.
I pre-ordered one already.
Interested and pre-ordered
Interested :slight_smile:
Purchased
