With the current MLCC shortage, I can’t get the capacitors that I want for the boost driver, they’re all sold out. I will order from mouser soon though, and get the best capacitors they currently have.
I think a user (Jensen) here managed to get either the H1-A or H2-C driver from into an s2+ by somehow mounting it behind/under the pill and, perhaps, grinding down the PCB to get it to fit.
H1-A is, I think, 20mm and boosts to 6v. H2-C is 22mm and boosts to 12v. I think, but I’m not sure, that the H1-A can be modded to higher compliance voltages.
I think I remember something like that, but all I could come up with a quick search was him building an S2+ into a MT-G2 with a H1-A. But yeah, he mounted the driver behind the pill instead of in it:
LOL, both of the boost drivers are still in the works, just on hold at the moment. Schoki is waiting for some components to get in stock at Muser last I heard and LoneOceans just got busy with life but still plans to do more work on it when he gets more time.
I still have a box for of components for prototyping whenever another prototype design is ready.
Very interesting, looks to be based on the same basic setup as the other drivers but impossible to say without seeing the other side.
I am guessing he ran into similar issues to the rest of us or it would be released already. It is proving very hard to get a stable driver in this form factor that can provide enough power for us.
Alphanumeric display displays menus, remaining battery voltage, LED drive current, CCA temperature, operational mode. The ability to define the number of presets and the intensity of each preset. A small uP could do this with ease, along with driving the power MOSFETS and other housekeeping chores… Instead of a timed interval for high power operation, have the processor look at heatsink temperature to keep the emitter and drive circuitry safe.
How about the display backlight changing colors to indicate remaining battery voltage?
Wi-fi and an app. Configure your light over wi-fi, using your phone or PC. Even easier, use a micro-USB cable.
I’m just curious, what is it that makes this type of small boost driver so difficult to produce? I’ve tried to read through this thread, and I think I understand that high current inductors are large and inefficient and get hot. But what is so special about the approaches Zebralight and Nightcore take to solve this problem, for example, with their xhp35 lights running on a single 18650.
Please understand, I’m not being critical at all; I’m in awe of the electronic wizards here on BLF. But I’m genuinely curious. Look at these images of a Zebralight SC600 mk 3. What is the magic here, and why have other companies and individuals been unable to do this?
I stole these images from a cpf thread, thanks Tachead:
