I brought CW MF04 out the other day. It is actually not to so bad with naked eyes. If you are comparing a long distance, CW does throw further when u compare with same XHP35 HI class NW emitter. However, NW will have the advantage for beam quality and CRI.
It is basically a high powered version of the Manker U21 or Utorch UT02. It is a thrower for sure with a 58mm SMO Reflector and it is fairly deep. I have lower powered versions from Utorch and they throw very well with useful spill. The lumintop version is likely to be much more impressive.
In comparison to the specs from Manker of the original U21:
1300 Lumen, 124,000 cd, 700m of throw distance. I found these numbers pretty accurate. It’s a good light.
Lumintop ODL20C Specs:
2,000 Lumen, 184,500 cd, 860m throw. A nice add is 2A built in charging.
I pre-ordered one already.
