Interested
Interested
Interested
“Continuous output levels” (doubleclick) is that ramping?
Size / dimensions? (or where can we see that?)
Need confirmation it’s XH70.2 not XHP70 like the description shows.
+1 for NW option.
I own Zanflare C4 and 21700 won’t fit.
Lii-500 and C4 are comparable in slot size. You could try out the new revisions of MiBoxer’s C4-12 and C8 (the one with 8 slots). MiBoxer recently announced them to be compatible even with protected 20700/21700 cells.
Interested depending on price. Can Liitokala Lii-500 and Zanflare C4 charge 21700 cells?
the flashlight is rechargeable ;)
Interested
Interested
interested depend on the price and tint
It looks pretty interesting.
4200 lumen from this size light is quite a feat. Most stick to around 3000-3500 due to heat build up. I wonder if this light will live up to it’s specs.
Those LiitoKala Lii-40A do look great for a 15A continous cell. Cheap too, at $5 each.
The UI on this light looks pretty wild. I wonder if they have tested it in actual use? The brightness levels seem good, but press and hold to turn off does not look appealing to me at all.
Count me interested, though. Maybe they will change the UI.
Interested
“Continuous output levels” this does mean ramping correct?
Where can we see the size / dimensions?
I was told today the first batch will be CW
if sales are good they think about a NW option in the next run.
In that case I’d be interested in the second batch, depending on the final UI
Dbl click from off seems to go to some type of ramping. They don’t mention if it gets memorized or not. Do not assume smooth NarsilM type ramping, though.
