Yep, even 1mm will have a noticeable effect. The same goes for the 1st piece of PVC as well, how hard it is pressed in can have a surprisingly noticeable effect on the readings.
Now factor that by the 4 joints in the sphere (which you had to take apart to make any changes and then reassemble to measure and hope you got it together with the same force every time, which you never did) and you start to see the tip of the iceberg these were to calibrate lol.
Missed this before, I have not tried much yet, until I have a more exact correction factor to aim for it is hard to know what will work.
I am thinking some form of DC-Fix type sheet is what I would like to use, unless I happen to find something that works perfectly. I am going to check home depot sometime to see what kind of options they have. Some very light window tint could work but I have a feeling it would drop the readings too much.
I also cut some discs out of the left over/broken diffusing sheets I used in the spheres to see if they happen to drop the readings by the right amount.
So i tested my fenix tk35ue… there is a guy name Kospap who tested the fenix tk35ue and we got similar result… I got 3486 lumen @30 seconds… below is his graph… look like my TA tube is working great with .70 factor.
Yes, the silver paint was an experiment to try to make things simpler but it didn’t work. Too bad, that reflective tape was way way more work then it seems.
I spent last night reading through all the posts - interesting stuff!
Curious, does ambient light impact the measurements at all? In other words, does it matter if the measurements are taken in a dark room vs outside in the sun?
I think it’s only fair to mention the MF02 has had at least three different driver versions with three different turbo output levels. When the MF02 first came out, turbo was about 1.8 amp. Then it got bumped up to about 2.2 amp. The very latest versions within the last month seem to have been bumped up to about 2.7 amp.
I just had some time to play with the lumen tube very briefly. It is VERY easy to use compared to my ceiling bounce and calculator method. It is also very consistent regardless of the flashlight head insertion depth, which is a sigh of relief because that was something I was worried about. The measurements are very high though as already confirmed by others. I get about 27.5k startup lumens on my MT09RTA whereas using my previous ceiling bounce standard, I was getting 22.8k startup lumens. Once TA gets the calibration corrected, this will be a fantastic device. I don’t regret my purchase a tiny bit I can tell it required alot of manual labor to construct this along with the discs.
Now I will have to store this away until I find a place to put this in my house. I’m out of room already. My room is already littered with flashslights and batteries.
