So, when can we expect to see our wooobins
From this update from 2 days ago: “Current estimate for the shipping date is late next week”
^ ^ See about 8 posts above ^ ^
Okay so I received my stock TO46R today. I ordered this before I came across this group buy. Anyway, first impressions! Really like this light despite the cool white in its stock form. About the same form factor as a BLF A6 but only a bit wider around the head due to heat sinking. The quality is top notch and the UI isn’t too bad either. Low mode of 7 lumens is a bit too high but I can live with it. I would recommend using a protected cell as I tested it with both types and it seems the unprotected cell doesn’t get compressed as hard and might increase resistance or disconnect when accidentally dropped. It’s obviously designed to be used with a protected cell because it comes with one and a protected cell sits flush with the end of the barrel.
It’s a great light and I highly recommend everyone to be patient. A high CRI NW version of this light will definitely be worth the wait.
Thanks KevinZA1988 for your feedback, good to hear you like it.
Status update: All GB lights are manufactured and ready to ship. Samples are traveling with DHL and are already in Germany -> they should arrive in Finland already tomorrow!
Reminder: Have you paid your reservations already?
Ps. There are still a couple of lights unclaimed. Send me a message to make a reservation.
So, that means “ready for shipping”, just pending for Maukka to test them. If Maukka gives a “PASSED” result for the CRI test, that’s the time the shipping will receive the “GO” signal. (hoping the result will not be anything other than a Passed result).
Thumbs up.
Yes. Exactly like that. Maukka will get the lights tomorrow, so we can expect the “PASSED” (“maukka approved”) stamp at latest on Wednesday.
NOTE: Please remember to add all required info when paying! Roughly ten members missed their phone number, which is necessary for shipping. If you forgot something, Wuben will contact you using your PayPal email => Please check your email and reply with the missing info in timely manner. Thanks!
I just paid for a 2nd TO46R from this GB (my friend is getting the other one as a birthday gift :sunglasses: )… I already have the stock TO46R and I love it, although I believe this NW high CRI version will replace it as my EDC light. If you haven’t paid yet, you’re gonna miss out on a great light. Thanks to everyone who made this GB possible.
Samples are here! They were randomly selected and shipped with full retail packaging. :sunglasses:
To my eyes, the desired color temperature and CRI definitely are there. maukka will get the lights tomorrow -> we know for sure after his tests.
[Tint shift is not significantly better than with 1st samples, but as we know: DC-fix will cure that]
Where do you buy DC-fix, and what type
Thanks
Robert
Paid for one TO46R. Thanks for arranging this.
D-C-Fix “Frost” FROST — d-c-fix - but almost any non-adhesive thick film with frost/fog effect should work well. My current sheet is probably a clone from LIDL.
This is only for making the beam more floody, or is it for color correction as well?
About how much will this reduce the output?
do you think,its possible to change the leds for brighter? xpl…or so…i mean home custom
It’s very easy to swap the emitters, unless they decided to glue the bezel in the new batch. You won’t get much more visible brightness though.
For normal outdoor usage, the light is good as is.
For photography, indoor usage, or just hunting white walls, it might be a good idea to apply DC-Fix. This will not only make the beam smoother and floodier, but also reduce the tint shift (towards green on the edge of spill).
Would be interesting to try XP-L2, but unfortunately, that would probably require also driver changes for any major gain. Has anyone tried this on his TO46R?
Thanks
Robert
You don’t need DC fix. These are standard Carclo optics. the slightly frosted 10508, and more frosted 10509 are what this light uses. The light comes with the clear Carclo 10507. I tried a 10508 in mine, and it smooths out the beam beautifully.
Thanks everybody for your input
Robert
Thanks The
Payment has been sent:
You sent $72.00 USD to 姚 巧敏
1-TO46R: $35 1-TO10R: $32 1- Extra emitter boards: $5 BLF
Thank for the updates on the process =the=! It is now closer to get the lights on our hands The light and emitters are paid!
Do we have to send you any kind of information or the info we sent to Wuben is enough?
[quote=the]
Hum, about this, I am not sure if - in terms of beam - the XP-L2 would be better! Brighter, for sure, but maye not better! I have 2 Sofirn lights that arrived with XP-L2 leds. One seemed more tending to 5000K and the other was a bit higher (5500 or 5700???).
However, both produce and yellowish and greenish tint shift similar to the one on the stock XP-G3 these Wuben lights have.
So…I am not sure if XP-L2 would be a good choice. However, a Luxeon V 4000 K, I guess that would be an interesting bet for these lights! No major shifts (or none), and a quite pleasant beam!!
But now let’s see how the leds we’re going to receive behave and that is the most important thing right now
