I don’t own it (I’m using a Bondhus set for my knives) but the Xiaomi/Whia set was a subject of discussion a few months ago in the All Things Budget Knife thread.
Some use it for knives and commented on it:
Exactly. Coupons in general do not work when the item is in flash sale like these screwdrivers right now. When flash sale is over coupon should work again - but price might be different.
Use coupon code 3a103e to get $18.87 price (-$11.08).
This is tried design based on prevalent C8 host with XP-L HI LED (1A, 3A and 3B tints available) and BLF A6 FET + 1xAMC driver.
This means this light will offer best throw from any C8 host as in turbo mode it’s essentially direct driven - so use high drain battery like Samsung 30Q above for maximum light output (stated 1300lm, spring bypass may be needed).
And of course same great UI as BLF A6 :+1:
That’s exactly the case. Right now there’s no 8x18650 extension tube for MF04, but I would expect this might be available in the future (all other Astrolux lights were 1:1 BLF design). I’ll try to find out.
Two designs to pick the one you like better (the only difference being the appearance of the knurling) - note this is not an extension tube - just different design to change flashlight style.
