I needed a clock. Banggood had some neat clock kits. Soldering each pixel individually was a bit of a pain, but now that everything is assembled, it looks nice.
The dot-matrix one had 6 pads per LED, and 105 LEDs, or 630 total pads to solder on the front side. It took a while. The other one had 216 pads on the front, IIRC, which also wasn’t the fastest process ever.
Today I got the Q8 MCPCB from led4power so I reflowed four of my favorite XM-L2 T3 7A3 CRI90 emitters in a my Q8:
I used a washer with two cut outs to clamp reflector to MCPCB :
The holes in the reflector was reamed out to fit this XM-L centering ring :
It was as reasonably straight forward mod, without any difficulties.
When I fired up the Q8 it wasn’t the nice tint I expected instead the beam had a green hue completely unlike the tint of the XM-L2 T3 7A3 CRI90 in the other flashlights I put it in.
Convoy M2 XM-L2 T3 7A3 CRI90 (left) BLF Q8 “XM-L2 T3 7A3 CRI90” (right)
One of the emitters have the “normal” 7A3 tint the other three have a green tone.
What a huge disappointment, and the next problem will be how to explain to the seller I got three emitters with different color :weary:
That is a bummer khas, those emitters are supposed to be super-nice!
One thing to check with your Q8, even though the tint difference between leds points to a led problem: is the lens AR-coated? That coated Q8 lens totally spoiled the tint of the LH351D leds in one of my Q8 lights, the non-AR coated lens of another Q8 made a world of a difference.
I referred to the stock AR lens that part of the Q8’s came with. I did order a KD replacement lens because it was said that it did not alter the tint as much but I did not receive it yet.
Those are really nice, and I miss the one I used to have, but nixie tubes are expensive… especially if I want a proper ‘5’ which isn’t just an upside-down ‘2’.
However, I’ve been tempted to get some nixie-like 16-segment VFD tubes, and connect it over USB for use as a general purpose 8-character display. I haven’t found any kits for that though; the closest was a clock which doesn’t talk to the USB host at all.
My Q8 had AR coating. I scrubbed it off, but it took a few hours with a polishing cloth. Tint was much better afterward.
Here’s a shot from halfway through that process. It was reflecting a big yellow light source, so the yellow parts were clean while the rest was still coated.
fwiw, lumens dropped by 50% and the light now runs noticeably hotter (dont have any IR temp data before and after, but I speculate its twice as hot, inverse of the lumen reduction)
neither the piss yellow of the XPL, nor the excess violet of the N219b are noticeable “in actual use”. The differences are only obvious when comparing different beams side by side.
