I am giving this guy a SF36 with a 30Q cell and a single cell charger and cable just for putting up with us. I even took off the crappy OEM pocket clip and put a A6 one on there. Just PM me with an address and it will be on the way.
This picture is wrong, the perspective greatly exaggerates the differences.
F1 is larger. Whether it’s much or a little larger - that’s personal taste.
But it’s not nearly that much larger.
I always say that a bit of humor can help diffuse a situation…
If you’re standing before a firing squad, a little joke or two can help relieve the tension on both sides as they fill you full of lead.
As I said it is a bit anfortunate angle, and we can also discuss how one defines “big”, i.e. what is big for you or me, but F1 definitely is larger relative to F1, if its say 50% extra volume-wise, which is roughky the case here
Zanflare F1 > A very nice light .
Yeah , charging - a decent dedicated charger should be on the shopping list if you plan to run 18650 .
Everyone is going to have personal preferences , but if you see the Zanflare F1 on special , it’s worth owning …
I got some F3’s when they were on special , and If I see the F1 on special again for $19.99 I will get another .
Can't say enough wonderful things about the BLF A6 flashlight from Banggood.com, bundled with the excellent Samsung 30Q (pink) 3000mah 18650 battery for $29USD ($26USD without the battery). Simply the finest EDC flashlight I've used, and a reflection of the community sourcing achievement of the members here. Best of luck to you..
Absolutely, still my favourite. Just this evening I was passing throuh a small town far from home and noticed a huge warehouse with a WE BUY AND SELL ANYTHING sign, it was about 4:30 and getting dark, they had no lighting inside but were open until 5. Out came the trusty A6 and I had to turn it down to output 5 of 7 to explore a building as large as an airplane hanger without blinding myself on the closer things. On turbo it lit up the whole place.
Magnificent light.
Zanflare on the other hand, I have ordered 4 on separate occasions, 3 were delivered and only one worked ( an F1).
