Your favourite CCT for your EDC FLASHLIGHT(S)
+1
Voted 4000k. Can live with +–3800k till 4400k
It used to be 3500K, but since some very good high CRI leds came out in 4000K, I like them better for my EDC.
Sounds like an easier question than it really is .
I like lots of different temp.lights but even within a bin there can be good and bad tints ….or maybe desirable and less desirable .:slight_smile:
3700k - 5000K
4500k if I had to pick only one
Voted 4500k simply because its bang in the middle of my fav temps. 5k for day and sometimes evening, 4k evening into night time is good for me. Can use anything in between……….
I also like 4k at night and 5k during the day. 4500k is a nice inbetween. My most used flashlight (S600 MK3 HI) also happens to be 4500k.
Recently I have become more aware of the fact that people’s perception of light and colour varies quite a bit. Probably changes with age as well. Personally I am happiest with 4500 to 5500 so voted 5000. I find 4000 makes colours look muddy or orange, unnaturally so to my eye, and this to me is far more disappointing than a 6500 light that makes colours look faded or washed out. BLF A6 neutral or Q8 is just about perfect to me, makes colours look more natural to me than any higher CRI light of different cct that I have, still don’t have a neutral high CRI to compare.
I tend to like between 4000K and 5000K, but I’ve liked lights outside that. I’d pick 5000K generally, but my most-used light is 4500K because that’s the 144A I could get at the time.
I vote the 5000K as an average. For indoor use and headlight I prefer 4000K to 5000K, but for outdoor use and thrower I like 5000K to 5700K.
Regards
Ulrich
Where can I find a 2000K (candle) LED? I would love to add a flashlight with this color temperature to my collection. Voted 4000K btw.
I have some, check my signature and go to the store. It’s not too efficient and cheap since they are premium high CRI version.
There are some alternatives out there too. Try googling them.
- Clemence
Wow! I would have thought that a 2000k HI CRI would be about as likely as a 6000k HI CRI LED. (Now you’re gonna tell me those exist too…)
I have the 2000K and 6500K both in R9080.
The 2000K rated at R9050 but Maukka test showed R9598 result
Now we need a multi-emitter CCT-blending flashlight using both of these and maybe a neutral or two also to balance the middle, for a “nearly full” CCT spectrum totally in HI CRI.
I think Ma Tumba already made one using these LEDs, VR16SP4 board, and Dr. Jones driver.
- Clemence
You said it Boaz. Wonder if anyone else. Gets it?
My favorite temps/tints are the ones I don’t notice. I also like temps/tints that play well with others.
My tint preference for flashlights:
I prefer 3000k as mood light in full darkness
I like 4000k in the evening when ambient is 3000k incandescent, but I dislike 4500k+ at that time
During the day, when my brain is white balanced to sunlight, I like 4500-6000k, and I dislike 3000k as too warm, at that time
but, if I dont compare the beam to anything, my brain white balances to all sorts of otherwise weird yellow, green, and violet tints, in a wide range of color temperatures
as a rule of thumb, I like the CCT of my flashlight to be slightly cooler (up to 1000k cooler) than the ambient white balance in that particular environment at the time of use
I voted 3000k as my most used light, because Im biased to low lumens and close range applications
Paisley
