GB 351D closed.
Oh okay then. Thought you had 90CRI LH351B.
Would’ve been great though. Thanks anyway.
I would be in for 4000K 90CRI LH351D (20 pieces)
Could you please notify me, when it will be available again?
Yes, of course.
Anyone know if 351D fits under carclo triple optics?
Yes, no problem.
The type doesn’t matter either. The beam is very nice with the clear/smooth spot version also
So… I see I managed to miss the 351D in 4000k… Looks like they may come back into stock? I am interested since the Vf is higher and I have a couple of triples that I would like to rebuild.
Great thanks! Now I need to figure out what host to use. I have way too many S2+
I prefer E2L. Lighter weight and you can access bezel easier to switch optics but overall not much different from S2+
@AEDe again, do you have 3000k 90CRI 351D emitters?
Thanks again for the response.
There are only 3 Hicri led in the shop I used.
1)351D 4000K 90cri
2)351B 3000k 90cri
3)XPG3 5700 90cri
All other variants available on order whith minimum 800-1000pcs with lead time obout 6 weeks.
If you need at least 500pcs. 351D 3000K 90cri(300pcs I can take for myself) we can arange order, but with a prepayment condition. I not have vacant >1000$
Mmmkay, for the time being sign me up for another bunch of 10x LH351D 4000K CRI90+ AEDe.
Already set and tested 6x for a room lamp under construction, and 2x in S2+ hosts with 30º TIRs. Had to reflow one for an S2+ twice, and I'm measuring at least 8% less light flux from its torch vs the other all else being equal. Wow…
Cheers ^:)
list updated
Put me down for:
(10) 351D 4000K 90CRI
(4) 351B 3000K 90CRI
Ship all at same time. No rush.
I’m interested in:
FB
Sorry if this is off-topic, but for the sake of completeness I have to add the explanation. The variation I measured in light flux between my recent S2+ builds isn't caused by faults in my reflow process, which I already have well mastered and allows me to do away with potential temperature related emitter damage. It is due to lens quality variation: Cree 30 Degree Angle Optical Lens (5-Pack) @ FastTech. Out of my 5-pack of lenses one is clearly brighter, the next two are good and about the same, the 4th one is a tad less bright but close, and the 5th one another bit less bright. Brightness delta between best and worst is ≈15%. Nuts…
Cheers :-)
In for another 2 of CRI70 5000k LH351D.
I am interested in 4x 351D 4000K 90CRI 5x 351B 3000K 90CRI
6x351D 4kK 90cri for me please.
Measurements and other data made me consider additional 30 pieces - probably will make several direct driven triplets and/or quads, thank you for your published measurement, djozz =)
Now interested in total of 50 pieces.
